Позволяет ли Access обновлять данные в присоедененной таблице Paradox
#32201104
Ссылка:
Из MSDN
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112.
ACC2002: Using Paradox Data with Access 2002 and Jet
Q286246
The information in this article applies to:
Microsoft Access 2002
Microsoft Data Access Components versions 2 . 1 , 2 . 1 SP1, 2 . 1 SP2, 2 . 5
Novice: Requires knowledge of the user interface on single-user computers.
This article applies to a Microsoft Access database (.mdb) and a Microsoft Access project (.adp).
For a Microsoft Access 2000 version of this article, see Q230126.
SYMPTOMS
The Paradox database driver works in one of two modes. One mode is when either
the Microsoft Jet 4 . 0 Service Pack 5 (SP5) or the Borland Database Engine (BDE) is
installed. The other mode is when neither of these are installed. Paradox data is
only updateable when Jet 4 . 0 SP5 or the BDE is installed. Without Jet 4 . 0 SP5 or
the BDE, Paradox data can be read, imported and exported, or linked to read-only.
There may be incompatibilities with certain versions of BDE. The symptoms of the
incompatibilities vary, depending upon the version of the BDE. Version 5 . 01 of the
Borland Database Engine is recommended. The following table lists the behavior
supported for each of the Paradox file formats:
Version Behavior
Paradox 3 , 4 , 5 ISAM Only Import\Export\Link-Read Only
Paradox 3 , 4 , 5 ISAM w/Jet 4 SP5 Import\Export\Link-Read Write
Paradox 3 , 4 , 5 ISAM w/BDE Import\Export\Link-Read Write
Paradox 7 - 8 No support provided
RESOLUTION
To be able to write data to a linked dbase file from within Access 2002 or a Jet 4 . 0
application you can install either Jet 4 . 0 SP5 or the BDE.
For additional information about how to obtain and install Jet 4 . 0 SP5, click the
article number below to view the article in the Microsoft Knowledge Base:
Q282010 ACC2002: Updated Version of Microsoft Jet 4 . 0 Available in Download
Center
NOTE: If you choose to install Jet 4 . 0 SP5, the linked Paradox table must have a
primary key to be updateable.
Contact Inprise Inc. or a third-party vendor to obtain the BDE. Obtain the licensing
and run-time distribution requirements for the BDE from Inprise.
Third-party Paradox ODBC driver vendors include Merant
(http://www.merant.com), Borland.Com (http://www.borland.com), and Inprise
Inc. (http://www.Inprise.com). For additional information about how to contact
Merant, Borland.Com, or Inprise Inc., please see the following articles in the
Q65416 Hardware and Software Third-Party Vendor Contact List, A-K
Q60781 Hardware and Software Third-Party Vendor Contact List, L-P
Q60782 Hardware and Software Third-Party Vendor Contact List, Q-Z
MORE INFORMATION
If neither Jet 4 . 0 SP5 nor the BDE is installed:
Microsoft Access does not prompt for, use, or maintain Paradox indexes as in
earlier versions of Microsoft Access. If Jet 4 . 0 SP5 or the BDE is installed, Access
uses and maintains the indexes.
APPEND, UPDATE, and DELETE are no longer supported.
Bulk writing of data to Paradox tables when using the INSERT INTO ... SELECT ...
FROM ... syntax remains supported; however the indexes are no longer maintained.
If the BDE is not installed:
The Paradox ISAM places an exclusive lock upon opening Paradox files. This
includes opening linked Paradox tables or Paradox tables opened via DAO.
Multi-user capability is no longer supported.
Concurrent ODBC connections to the same table, from the same computer, or from
multiple computers, is no longer supported.
The Paradox ISAM only supports the 8 . 3 naming convention as in earlier version of
Microsoft Access.
Paradox extensions are not supported via the Microsoft Paradox IISAM, regardless
of whether a version of the BDE is installed that supports it.
REFERENCES
For additional information about other drivers that use Jet 4 . 0 SP5 or the BDE in a
similar way, click the article number below to view the article in the Microsoft
Knowledge Base:
Q290867 ACC2002: Using dBASE Data with Access 2002 and Jet
The third-party products discussed in this article are manufactured by vendors
independent of Microsoft; we make no warranty, implied or otherwise, regarding
these products' performance or reliability.
