Kak vipolnith If Then - zaprashivajet Object Required
Private Sub vdDatums_DblClick(Cancel As Integer) On Error GoTo Err_cmdVizite_Click Dim stDocName As String Dim stLinkCriteria As String If Me!vdDatums Is Null Then 'Jesli v pole vdDatums netu znachenij to voditsa sevodneshneje chislo Me!vdDatums = Date DoCmd.RunCommand acCmdSaveRecord End If 'Jelsi v pole vdDatums uze jesth chislo to prosta otkrivajetsa forma stDocName = "frmVizitesPersona" DoCmd.OpenForm stDocName, , , stLinkCriteria DoCmd.Close acForm, Me.Name Exit_cmdVizite_Click: Exit Sub Err_cmdVizite_Click: MsgBox Err.Description Resume Exit_cmdVizite_Click End Sub No pri shelchkah na pole on zaprashivajet Object Required. Mozna li v Forme gde vdDatums v novoi stroke po defoltu stajath uze sevodneshneje chislo? ... |
| 25.08.2003, 13:01 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1679751]: |
47ms |
50ms |
| others: | 190ms |
| total: | 337ms |
