ADP, CreateParameter
vsem privet i izvenite za latinizy accessXP-ADP hohu vipolnit proceduru CREATE PROCEDURE dbo.sp_AddFloor(@BuildingID int, @FloorNum smallint, @account varchar(13)) AS INSERT INTO dbo.Floor (BuildingId, FloorNum, account) VALUES (@BuildingID, @FloorNum, @account) GO vot vipolnenie: Dim cnn As ADODB.Connection Dim cmd As ADODB.Command Dim prm As ADODB.Parameter Dim varrecs As Variant Dim CodeFloor As Integer Dim strParam As String CaptionParameter1 = " ÷åã îñôø ÷åîä " DoCmd.OpenForm "F_Parameters" If Trim(ValueParameter1) <> "0" Then Set cnn = CurrentProject.Connection Set cmd = New ADODB.Command cmd.ActiveConnection = cnn cmd.CommandText = "sp_AddFloor" cmd.CommandType = adCmdStoredProc Set prm = cmd.CreateParameter("buildingID", adInteger, adParamInput, , Me!BuildingId) cmd.Parameters.Append prm Set prm = cmd.CreateParameter("FloorNum", adSmallInt, adParamInput, , CInt(Trim(ValueParameter1))) cmd.Parameters.Append prm strParam = Trim(Forms!F_Buildings!short & Format(Trim(ValueParameter1), "000") & "00") Set prm = cmd.CreateParameter("account", adVarChar, adParamInput, , strParam) cmd.Parameters.Append prm cmd.Execute varrecs Debug.Print varrecs Set prm = Nothing Set cmd = Nothing cnn.Close Set cnn = Nothing Me.Refresh End If na stroke Set prm = cmd.CreateParameter("account", adVarChar, adParamInput, , strParam) access oret pro parametr : Parameter object is improperly defined.Inconsistent or in complete information was provided ne ponimau cto delau ne pravilno ... |
| 13.05.2004, 10:17 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1674687]: |
170ms |
43ms |
| others: | 227ms |
| total: | 490ms |
