Как сгенерить??
Я бы сделал так: Sub codes() Dim rec As DAO.Recordset Set rec = CurrentDb.OpenRecordset("Соответст") On Error Resume Next rec.MoveFirst Randomize Timer Do rec.Edit do do Err.Clear rec![Текущие коды] = 1 + Int(Rnd * 999999) loop while Err.number rec.Update loop while Err.number rec.MoveNext Loop Until rec.EOF On Error GoTo 0 Set rec = Nothing End Sub ... |
| 25.05.2004, 18:32 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1674379]: |
154ms |
27ms |
| others: | 247ms |
| total: | 468ms |
