listbox. значения в цикле
подскажите, плз, как мне в цикле вытащить значения второго столбца листбокса? Код: plaintext 1. 2. 3. 4. 5. ... |
| 28.06.2004, 11:56:31 |
Column(1,номер_строки) ... |
| 28.06.2004, 12:03:26 |
Код: plaintext 1. 2. 3. 4. авторUse 0 to refer to the first column, 1 to refer to the second column, and so on. Use 0 to refer to the first row, 1 to refer to the second row, and so on. For example, in a list box containing a column of customer IDs and a column of customer names, you could refer to the customer name in the second column and fifth row as: Forms!Contacts!Customers.Column(1, 4) ... |
| 28.06.2004, 12:05:14 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1673564]: |
274ms |
49ms |
| others: | 187ms |
| total: | 565ms |
