База Access + MySQL
Shuhard softmaster какой может быть скрипт скрипт генерации таблицы на MySql для чего топаешь в bin и делаешь Dump примерно так: пример--->mysqldump mysql user > d:\1.txt сделай mysqldump твоя_база твоя_таблица > твой_текстовый_файл ------------------------------------- d:\1.txt ---------------------- -- MySQL dump 8.22 -- -- Host: localhost Database: mysql --------------------------------------------------------- -- Server version 3.23.55-nt -- -- Table structure for table 'user' -- CREATE TABLE user ( Host char(60) binary NOT NULL default '', User char(16) binary NOT NULL default '', password char(16) NOT NULL default '', Select_priv enum('N','Y') NOT NULL default 'N', Insert_priv enum('N','Y') NOT NULL default 'N', Update_priv enum('N','Y') NOT NULL default 'N', Delete_priv enum('N','Y') NOT NULL default 'N', Create_priv enum('N','Y') NOT NULL default 'N', Drop_priv enum('N','Y') NOT NULL default 'N', Reload_priv enum('N','Y') NOT NULL default 'N', Shutdown_priv enum('N','Y') NOT NULL default 'N', Process_priv enum('N','Y') NOT NULL default 'N', File_priv enum('N','Y') NOT NULL default 'N', Grant_priv enum('N','Y') NOT NULL default 'N', References_priv enum('N','Y') NOT NULL default 'N', Index_priv enum('N','Y') NOT NULL default 'N', Alter_priv enum('N','Y') NOT NULL default 'N', PRIMARY KEY (Host,User) ) TYPE=MyISAM COMMENT='Users and global privileges'; -- -- Dumping data for table 'user' -- INSERT INTO user VALUES ('localhost','root','','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y'); INSERT INTO user VALUES ('%','root','','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y'); INSERT INTO user VALUES ('localhost','','','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y'); INSERT INTO user VALUES ('%','','','N','N','N','N','N','N','N','N','N','N','N','N','N','N'); INSERT INTO user VALUES ('localhost','admin','43e9a4ab75570f5b','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y','Y'); INSERT INTO user VALUES ('localhost','inna','12345','N','N','N','N','N','N','N','N','N','N','N','N','N','N'); Insert оставь себе,Create Table выложи на конфу Дамп не получился сохранить пишет в конце C:\MYSQL\BIN\MYSQLD~1.EXE: Can't get info about table: 'c:\1.txt' error: Incorrect table name 'c:\1.txt' ... |
| 25.08.2004, 13:05:05 |
База Access + MySQL
REATE TABLE users ( user_id int(11) default NULL auto_increment, user_sid int(11) NOT NULL default '0', user_name varchar(128) default NULL, user_birthdate date default NULL, department_id int(11) default NULL, token_id int(11) default NULL, token_sid int(11) default NULL, notes varchar(128) default NULL, login varchar(64) default NULL, passwd varchar(16) default NULL, admin_type enum('N','Y') default NULL, start_reader_id int(11) default NULL, start_reader_sid int(11) default NULL, end_reader_id int(11) default NULL, end_reader_sid int(11) default NULL, pic varchar(128) default NULL, PRIMARY KEY (user_id,user_sid) ) TYPE=MyISAM ... |
| 25.08.2004, 13:21:02 |
База Access + MySQL
2 softmaster читай, там есть ответ на твой вопрос: http://dev.mysql.com/doc/mysql/ru/MyODBC_clients.html ... |
| 26.08.2004, 00:07:22 |
База Access + MySQL
сравни скрипты - в моём всё работает,таблица обновляемая через ODBC в Acc XP/mdb автор use mysql; DROP TABLE IF EXISTS My_Users; CREATE TABLE My_users ( user_id int(11) NOT NULL auto_increment, user_sid int(11) NOT NULL , user_name varchar(128) default NULL, user_birthdate date default NULL, department_id int(11) default NULL, token_id int(11) default NULL, token_sid int(11) default NULL, notes varchar(128) default NULL, login varchar(64) default NULL, passwd varchar(16) default NULL, admin_type enum('N','Y') default NULL, start_reader_id int(11) default NULL, start_reader_sid int(11) default NULL, end_reader_id int(11) default NULL, end_reader_sid int(11) default NULL, pic varchar(128) default NULL, PRIMARY KEY (user_id,user_sid) ) TYPE=MyISAM; ... |
| 26.08.2004, 08:17:28 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1672209]: |
49ms |
37ms |
| others: | 204ms |
| total: | 337ms |
