почему код с использованием CurrentDb.Execute не работает?
Он работает только с DoCmd.RunSQL :-( акцXP mdb Private Sub cmdAddModel_Click() On Error GoTo ErrHANDLEr If IsNull(ÑïÔÈÎ) Then Exit Sub Dim s As String, strNARM As String, Eq As String Dim v Dim st Dim strModelID As String Dim strArmID As String Dim strPrim2 As String Dim strNomARM Dim strStik Dim strPr2 Dim srtPar2 As String strModelID = Str(Form_Ôîðìà1.txtModel.Value) ' MsgBox ("1text:" & strModelID & ":") strNomARM = Form_frmQryARM.nARM ' MsgBox ("3text:" & strNomARM & ":") s = "select top 1 OborudID from gaga_tblModel WHERE ModelID=" & strModelID v = CurrentProject.Connection.Execute(s).GetRows Eq = CStr(v(0, 0)) ' MsgBox ("2text:" & ":") ' MsgBox (Eq) strArmID = Str(Form_Ôîðìà1.ñïÀÐÌ.Value) ' MsgBox (strArmID) s = "SELECT MAX(CInt(prim2)) FROM gaga_tblModelARM AS MA, gaga_tblModel AS M" _ & " WHERE MA.ModelID = M.ModelID AND ARMID=" & strArmID & " And M.OborudID=" & Eq v = CurrentProject.Connection.Execute(s).GetRows strPrim2 = CStr(Nz(v(0, 0), "0")) strPrim2 = CStr(CInt(strPrim2) + 1) ' MsgBox (strnVnutr) s = "select top 1 foStiker from gaga_tblOborud WHERE OborudID=" & ÑïÊîëÎáîðóä v = CurrentProject.Connection.Execute(s).GetRows strStik = CStr(Nz(v(0, 0), "N")) 'MsgBox ("4text:" & strStik & ":") st = strNomARM & "-" & strStik & strPrim2 ' & IIf(IsNull(srtPar2), "-" & srtPar2, "") ' s = "INSERT INTO gaga_tblModelARM (ARMID, ModelID, prim2, nVnutr) VALUES (ñïÀÐÌ, [Forms]![Ôîðìà1]![txtModel]," & strPrim2 & ", '" & st & "')" ' s = "INSERT INTO gaga_tblModelARM ( ARMID, ModelID ) SELECT gaga_tblARM.ARMID, gaga_tblModel.ModelID FROM gaga_tblARM, gaga_tblModel WHERE (((gaga_tblARM.ARMID)=ñïÀÐÌ ) AND ((gaga_tblModel.ModelID)=[Forms]![Ôîðìà1]![txtModel]))" DoCmd.RunSQL s ErrHANDLEr: End Sub ... |
| 07.12.2004, 17:27:55 |
попробуй так: Currentdb.Execute s,dbfailonerror и какую ошибку при этом выкинет? ... |
| 07.12.2004, 17:33:07 |
Kelmeпопробуй так: Currentdb.Execute s,dbfailonerror и какую ошибку при этом выкинет? CurrentDb.Execute s, DB_FAILONERROR ошибка: слишком мало параметров. требуется 2 ... |
| 07.12.2004, 17:42:21 |
типа так: Код: plaintext 1. ... |
| 07.12.2004, 17:45:28 |
ссылки на поля формы при currenddb.execute не работают. "VALUES (ñïÀÐÌ, [Forms]![Ôîðìà1]![txtModel]," нужно заменить на "VALUES (ñïÀÐÌ, " & [Forms]![Ôîðìà1]![txtModel] & "," ... |
| 07.12.2004, 17:45:48 |
Alexey Shссылки на поля формы при currenddb.execute не работают.поищи по форуму где то фак не добитый там расписано как обходить. ... |
| 07.12.2004, 17:52:24 |
Kelmeтипа так: Код: plaintext 1. СПАСИБО! ПОЛУЧИЛОСЬ! :-) ps получается, что ранэскуэль более сговорчивый :-) ... |
| 07.12.2004, 18:01:18 |
Обходить можно при помощи Код: plaintext ... |
| 07.12.2004, 18:01:25 |
здесь та же проблема: CurrentDb.Execute не работает ошибка: Необходимо использование параметра dbSeeChanges с OpenRecordset при доступе к таблице SQLServer, которая имеет столбец IDENTITY. (Ошибка 3622) Private Sub txtSistBlParent_AfterUpdate() Form_Frmgaga_tblModelARM1Sub.Refresh Dim s As String Dim st Dim strNomARM Dim strStik Dim strPr2 Dim srtPar2 As String Dim strNomVn As String Dim strModelARMID As String strNomARM = Form_frmQryARM.nARM strStik = Form_Frmgaga_tblModelARM1Sub.txtStiker strPr2 = Form_Frmgaga_tblModelARM1Sub.txtprim2 Form_Frmgaga_tblModelARM1Sub.txtP.SetFocus srtPar2 = CStr(Form_Frmgaga_tblModelARM1Sub.txtP.Text) st = strNomARM & "-" & strStik & strPr2 & IIf(IsNull(srtPar2), "", "-" & srtPar2) Form_Frmgaga_tblModelARM1Sub.txtnVnutr.SetFocus strModelARMID = CStr(Form_Frmgaga_tblModelARM1Sub.ModelARMID.Value) s = "UPDATE gaga_tblModelARM SET nVnutr='" & st & "' WHERE ModelARMID=" & strModelARMID 'CurrentProject.Connection.Execute (s) CurrentDb.Execute s Form_Frmgaga_tblModelARM1Sub.Requery Form_Ôîðìà1.txtTest.SetFocus End Sub ... |
| 09.12.2004, 10:49:14 |
много раз обсужденный вопрос /topic/92933&pg=1&hl=dbuseodbc ... |
| 09.12.2004, 11:00:21 |
Shuhardмного раз обсужденный вопрос /topic/92933&pg=1&hl=dbuseodbc к сожалению сама разобраться не смогла:( поэтому просто отключу подтверждения в меню Акц. и вернусь к RunSQL ... |
| 09.12.2004, 11:31:23 |
start [/forum/topic.php?fid=45&gotonew=1&tid=1669861]: |
27ms |
44ms |
| others: | 212ms |
| total: | 329ms |
