Informix KAIO and storage
Hellou ! I have proble with configuration Informix KAIO with dabaspaces on a stograge. According to release notes there are two ways in making async device. If am using storage with HP-UX (look ptk. 2 below) what command I shiuld use: /usr/sbin/mknod /dev/async c 101 0 or /usr/sbin/mknod /dev/async c 101 4 ? o. HP KAIO driver "asyncdsk" is installed and linked into the kernel. o. To ensure KAIO driver is up and running, check to see if there is /dev/async, if not follow these steps: 1) su root 2) If using HP hardware/OS redundancy or mirroring then create the async device as follows: /usr/sbin/mknod /dev/async c 101 0 else if using Informix mirroring or no hardware/OS mirroring or no mirroring at all then create the async device as follows: /usr/sbin/mknod /dev/async c 101 4 3) chmod 0666 /dev/async thanks Mark ... |
| 21.10.2004, 22:16 |
slusarekHellou ! I have proble with configuration Informix KAIO with dabaspaces on a stograge. According to release notes there are two ways in making async device. If am using storage with HP-UX (look ptk. 2 below) what command I shiuld use: /usr/sbin/mknod /dev/async c 101 0 or /usr/sbin/mknod /dev/async c 101 4 ? o. HP KAIO driver "asyncdsk" is installed and linked into the kernel. o. To ensure KAIO driver is up and running, check to see if there is /dev/async, if not follow these steps: 1) su root 2) If using HP hardware/OS redundancy or mirroring then create the async device as follows: /usr/sbin/mknod /dev/async c 101 0 else if using Informix mirroring or no hardware/OS mirroring or no mirroring at all then create the async device as follows: /usr/sbin/mknod /dev/async c 101 4 3) chmod 0666 /dev/async thanks Mark What kind of volumes are there on the storage? Is they redundant? If your volumes is redundant and you don't going to use informix mirroring , use the first comand. With regards. ... |
| 22.10.2004, 14:22 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1609188]: |
73ms |
53ms |
| others: | 251ms |
| total: | 439ms |
