ISAM error -ошибка в индексах в системной таблице
При запуске oncheck -cI dbname выдает, что есть ошибка в индексах системной таблицы sysprocbody ======================== Validating indexes for dbname:informix.sysprocbody... Index procbody Could not check rowids and perform data<->index check ISAM error: Primary and Mirror chunks are bad Собственно вопрос: как это лечится? ======================== пробовала удалить/создать индекс типа: ======================== drop index procbody; CREATE UNIQUE INDEX procbody ON sysprocbody(procid, datakey, seqno); ======================== выдает: ======================== Database selected. 511: Cannot modify system catalog (sysprocbody). Error in line 1 Near character position 18 511: Cannot modify system catalog (sysprocbody). Error in line 1 Near character position 66 Database closed. ======================== Что в общем-то естественно, но как это лечится - не понятно. Кто-нибудь сталкивался с подобным? ... |
| 02.12.2004, 13:56 |
---- ADMIN GUIDE -------- If you run oncheck -cI while the database server is in on-line mode, oncheck detects the corruption but does not prompt you for repairs. If corruption exists, you can drop and re-create the indexes using SQL statements while you are in on-line mode (the database server locks the table and index). If you run oncheck -cI in quiescent mode, and corruption is detected, oncheck prompts you to confirm whether the utility should attempt to repair the corruption. ... |
| 02.12.2004, 17:15 |
AS a last resort you can dbexport/dbimport your database. Also check this : http://groups-beta.google.com/group/comp.databases.informix/browse_thread/thread/b0a9276a6257ef6b/cfd9eba02cc8a797?q=informix+corrupted+index+system+table&_done=%2Fgroups%3Fq%3Dinformix+corrupted+index+system+table+%26hl%3Den%26lr%3D%26sa%3DN%26tab%3Dwg%26&_doneTitle=Back+to+Search&&d#cfd9eba02cc8a797 ... |
| 02.12.2004, 17:23 |
vybegallo---- ADMIN GUIDE -------- If you run oncheck -cI while the database server is in on-line mode, oncheck detects the corruption but does not prompt you for repairs. If corruption exists, you can drop and re-create the indexes using SQL statements while you are in on-line mode (the database server locks the table and index). If you run oncheck -cI in quiescent mode, and corruption is detected, oncheck prompts you to confirm whether the utility should attempt to repair the corruption. Понятно, что если делать в онлайн-режиме он ничего не исправит, а только найдет. Переводили сервер в quiescent mode (oninit -s), он находил эту ошибку, но исправить ее не мог. Поэтому и пыталась убить/создать на нем индексы. Да, делалось это под пользователем informix. Но как видите - безрезультатно. ... |
| 02.12.2004, 18:15 |
Может у вас диски неисправны ? Стоит их проверить если исправление логической структуры в пространствах не помогает. А primary и mirror чанки у вас на разных дисках или на одном ? ... |
| 03.12.2004, 09:40 |
AndronМожет у вас диски неисправны ? Стоит их проверить если исправление логической структуры в пространствах не помогает. А primary и mirror чанки у вас на разных дисках или на одном ? Может и диски неисправны. Чем проверить (на Linux)? fscheck -ом? Судя по всему primary и mirror чанки на разных дисках: из onconfig -a: ================================= ROOTPATH /dbs_pri/dbname/root01.dbf MIRRORPATH /dbs_mir/dbname/root01.dbf ================================= вот что выдает df: ================================= /dev/sdb1 8815372 656040 7711524 8% /dbs_pri/dbname /dev/sdc1 8815372 656040 7711524 8% /dbs_mir/dbname ================================= ... |
| 03.12.2004, 12:53 |
Ну тут или в саппорт звонить, или выгружать-загружать базу. ... |
| 03.12.2004, 20:37 |
vybegalloНу тут или в саппорт звонить, или выгружать-загружать базу. саппорта нету. выгружать- загружать это dbexport/dbimport? надо ли загружать ее на новый сервак, либо на тот же? и типа должно помочь? ... |
| 06.12.2004, 12:03 |
На этот же. Если выгрузится - то должно помочь, поскольку индексы в новой базе будут построены заново. Чанки проверить можно командой dd if=<chunk name> of=/dev/null bs=2k count=<# of pages in chunk> ... |
| 06.12.2004, 17:59 |
vybegalloНа этот же. Если выгрузится - то должно помочь, поскольку индексы в новой базе будут построены заново. Чанки проверить можно командой dd if=<chunk name> of=/dev/null bs=2k count=<# of pages in chunk> их проверять после выгрузки базы? а где про эти проверки почитать? ... |
| 10.12.2004, 11:51 |
нет, их проверять до переноса. Почитать надо man dd Все, что dd делаеи - читает из одного файла (чанка) и копирует в другой (/dev/null ). Таким образом проверяется всего лишь читаемость чанков. Логическая целостность проверяется oncheck-ом. ... |
| 10.12.2004, 17:01 |
vybegalloнет, их проверять до переноса. Почитать надо man dd Все, что dd делаеи - читает из одного файла (чанка) и копирует в другой (/dev/null ). Таким образом проверяется всего лишь читаемость чанков. Логическая целостность проверяется oncheck-ом. то есть в таком варианте все можно проверить на рабочих серверах, и никаких изменений он не сделает. а тока проверит целостность? ... |
| 10.12.2004, 17:37 |
vybegalloЧанки проверить можно командой dd if=<chunk name> of=/dev/null bs=2k count=<# of pages in chunk> chank name как я понимаю можно посмотреть в базе sysmaster Select chknum, fname From syschunks а откуда вытащить инфу о числе страниц в чанке? ... |
| 10.12.2004, 17:51 |
onstat -d ... Chunks address chk/dbs offset size free bpages flags pathname 1e10f918 1 1 25 999975 139791 PO- /dev/central1_rootdbs you need size, offset and pathname. count = size + offset ... |
| 10.12.2004, 19:39 |
ladyirina а откуда вытащить инфу о числе страниц в чанке? "Из того же материала" (с) chksize из таблицы syschunks ... |
| 14.12.2004, 15:41 |
Daugava ladyirina а откуда вытащить инфу о числе страниц в чанке? "Из того же материала" (с) chksize из таблицы syschunks И что, можно эту проверку запускать прямо на рабочем сервере, не останавливая его? А конфликты не возникнут? ... |
| 15.12.2004, 12:08 |
С какой стати быть конфликтам? dd никого не блокирует. ... |
| 15.12.2004, 12:40 |
вот что получилось в итоге по проверке чанков: то,что выдает "Select chknum, fname, chksize From syschunks": ====================================== chknum fname chksize 1 /dbs_pri/dbname1/root01.dbf 65536 2 /dbs_pri/dbname2/work03.dbf 900000 4 /dbs_pri/dbname2/work01.dbf 768000 5 /dbs_pri/dbname2/work02.dbf 768000 7 /dbs_pri/dbname2/blob01.dbf 768000 8 /dbs_pri/dbname1/log01.dbf 65536 9 /dbs_pri/dbname1/log02.dbf 65536 10 /dbs_pri/dbname1/log03.dbf 65536 11 /dbs_pri/dbname1/log04.dbf 65536 12 /dbs_tmp/tmp01.dbf 131072 13 /dbs_tmp/tmp02.dbf 131072 14 /dbs_tmp/tmp03.dbf 131072 15 /dbs_tmp/tmp04.dbf 131072 16 /dbs_tmp/tmp05.dbf 131072 17 /dbs_tmp/tmp06.dbf 131072 18 /dbs_tmp/tmp07.dbf 131072 19 /dbs_tmp/tmp08.dbf 131072 ====================================== то, что выдает dd на каждый чанк: ====================================== # dd if=/dbs_pri/dbname1/root01.dbf of=/dev/null bs=2k count=65536 65536+0 records in 65536+0 records out # dd if=/dbs_pri/dbname2/work03.dbf of=/dev/null bs=2k count=900000 900000+0 records in 900000+0 records out # dd if=/dbs_pri/dbname2/work01.dbf of=/dev/null bs=2k count=768000 dd: /dbs_pri/dbname2/work01.dbf: Input/output error 270534+0 records in 270534+0 records out # dd if=/dbs_pri/dbname2/work02.dbf of=/dev/null bs=2k count=768000 768000+0 records in 768000+0 records out # dd if=/dbs_pri/dbname1/log01.dbf of=/dev/null bs=2k count=65536 65536+0 records in 65536+0 records out # dd if=/dbs_pri/dbname1/log02.dbf of=/dev/null bs=2k count=65536 65536+0 records in 65536+0 records out # dd if=/dbs_pri/dbname1/log03.dbf of=/dev/null bs=2k count=65536 65536+0 records in 65536+0 records out # dd if=/dbs_tmp/tmp01.dbf of=/dev/null bs=2k count=131072 131072+0 records in 131072+0 records out # dd if=/dbs_tmp/tmp02.dbf of=/dev/null bs=2k count=131072 131072+0 records in 131072+0 records out # dd if=/dbs_tmp/tmp03.dbf of=/dev/null bs=2k count=131072 131072+0 records in 131072+0 records out # dd if=/dbs_tmp/tmp04.dbf of=/dev/null bs=2k count=131072 131072+0 records in 131072+0 records out # dd if=/dbs_tmp/tmp05.dbf of=/dev/null bs=2k count=131072 131072+0 records in 131072+0 records out # dd if=/dbs_tmp/tmp06.dbf of=/dev/null bs=2k count=131072 131072+0 records in 131072+0 records out # dd if=/dbs_tmp/tmp07.dbf of=/dev/null bs=2k count=131072 131072+0 records in 131072+0 records out # dd if=/dbs_tmp/tmp08.dbf of=/dev/null bs=2k count=131072 131072+0 records in 131072+0 records out ====================================== Ну я вижу ошибку в чанке /dbs_pri/dbname2/work01.dbf но что можно с этим сделать? ... |
| 22.12.2004, 13:00 |
да, df выдает об этом диске, где поломанный чанк /dev/sdb2 8823436 6414296 1960928 77% /dbs_pri/dbname2 ну хорошо, а дальше то что с этим делать? понятно, что винт надо менять а кроме? можно как-то все скинуть куда-то временно? задача-то была в итоге сделать бэкап да, кстати,никто не знает, почему такое происходит: в onconfig -е проставлено, что имеет место зеркалирование =============================== MIRROR 1 # Mirroring flag (Yes = 1, No = 0) MIRRORPATH /dbs_mir/dbname/root01.dbf # Path for device containing mirrored root MIRROROFFSET 0 # Offset into mirrored device (Kbytes) =============================== диски подключены все =============================== # df Filesystem 1k-blocks Used Available Use% Mounted on /dev/sda2 8064304 2378396 5276252 31% / /dev/sda5 4032092 3007996 819272 79% /home /dev/sda6 1011928 270564 689960 28% /opt /dev/sda8 2498348 893200 1478240 38% /opt2 /dev/sda7 1517920 92 1440720 0% /tmp /dev/sdb1 8815372 656040 7711524 8% /dbs_pri/dbname1 /dev/sdb2 8823436 6414296 1960928 77% /dbs_pri/dbname2 /dev/sdc1 8815372 656040 7711524 8% /dbs_mir/dbname1 /dev/sdc2 8823436 6414296 1960928 77% /dbs_mir/dbname2 /dev/sdd2 17640244 6229928 10514216 37% /export /dev/sde1 17639220 14763828 1979372 88% /backup =============================== однако, в инфе, которую выдает "Select chknum, fname, chksize From syschunks" никакого упоминания о наличие чанков на зеркальных дисках нет. это нормально? они есть или все таки их нет? ... |
| 22.12.2004, 13:16 |
Зачем так сложно - лезть в системные таблицы чтобы посмотреть есть ли зеркальные чанки ? Используйте проверенную временем команду onstat -d ;-) ... |
| 22.12.2004, 14:22 |
AndronЗачем так сложно - лезть в системные таблицы чтобы посмотреть есть ли зеркальные чанки ? Используйте проверенную временем команду onstat -d ;-) Да по сложности одинаково. Можно и так. Вопрос-то не в этом. А что с этим делать? ... |
| 22.12.2004, 14:34 |
1. приведите результаты команды onstat -d 2. что делать - спасать данные, менять диск, заливать данные заново. Это если нет бэкапа. Если есть - то менять диск, восстанавливаться из бэкапа, накатывать логи. Спасать данные - либо dbexport, либо вручную (скриптами) выгружать в файлы. ontape , onbar не будут архивировать битый диск - и нет в этом никакого смысла. ... |
| 22.12.2004, 16:52 |
vybegallo1. приведите результаты команды onstat -d 2. что делать - спасать данные, менять диск, заливать данные заново. Это если нет бэкапа. Если есть - то менять диск, восстанавливаться из бэкапа, накатывать логи. Спасать данные - либо dbexport, либо вручную (скриптами) выгружать в файлы. ontape , onbar не будут архивировать битый диск - и нет в этом никакого смысла. Informix Dynamic Server 2000 Version 9.21.UC4 -- On-Line -- Up 14 days 18:53:45 -- 151096 Kbytes Dbspaces address number flags fchunk nchunks flags owner name 14ccd7d0 1 0x2 1 1 M informix root_dbs 1538db98 3 0x2 4 3 M informix work2_dbs 1538dce0 5 0x12 7 1 M B informix blob2_dbs 1538de28 6 0x2 8 4 M informix log_dbs 1525b018 7 0x2001 12 8 N T informix tmp_dbs 5 active, 2047 maximum Chunks address chk/dbs offset size free bpages flags pathname 14ccd918 1 1 0 65536 63242 PO- /dbs_pri/dbname1/root01.dbf 14ccda88 1 1 0 65536 0 MO- /dbs_mir/dbname1/root01.dbf 14d0c320 2 3 0 900000 749597 PO- /dbs_pri/dbname2/work03.dbf 1538d018 2 3 0 900000 0 MO- /dbs_mir/dbname2/work03.dbf 14d0c490 4 3 0 768000 49 PO- /dbs_pri/dbname2/work01.dbf 1538d188 4 3 0 768000 0 MD- /dbs_mir/dbname2/work01.dbf 14d0c600 5 3 0 768000 22315 PO- /dbs_pri/dbname2/work02.dbf 1538d2f8 5 3 0 768000 0 MO- /dbs_mir/dbname2/work02.dbf 14d0c770 7 5 0 768000 ~95952 96000 POB /dbs_pri/dbname2/blob01.dbf 1538d468 7 5 0 768000 0 MOB /dbs_mir/dbname2/blob01.dbf 14d0c8e0 8 6 0 65536 8139 PO- /dbs_pri/dbname1/log01.dbf 1538d5d8 8 6 0 65536 0 MO- /dbs_mir/dbname1/log01.dbf 14d0ca50 9 6 0 65536 65533 PO- /dbs_pri/dbname1/log02.dbf 1538d748 9 6 0 65536 0 MO- /dbs_mir/dbname1/log02.dbf 14d0cbc0 10 6 0 65536 65533 PO- /dbs_pri/dbname1/log03.dbf 1538d8b8 10 6 0 65536 0 MO- /dbs_mir/dbname1/log03.dbf 14d0cd30 11 6 0 65536 65533 PO- /dbs_pri/dbname1/log04.dbf 1538da28 11 6 0 65536 0 MO- /dbs_mir/dbname1/log04.dbf 14d0cea0 12 7 0 131072 130733 PO- /dbs_tmp/tmp01.dbf 14ccdbf8 13 7 0 131072 131069 PO- /dbs_tmp/tmp02.dbf 14ccdd68 14 7 0 131072 131069 PO- /dbs_tmp/tmp03.dbf 14cfd830 15 7 0 131072 131069 PO- /dbs_tmp/tmp04.dbf 14cfd9a0 16 7 0 131072 131069 PO- /dbs_tmp/tmp05.dbf 14cfdb10 17 7 0 131072 131069 PO- /dbs_tmp/tmp06.dbf 14cfdc80 18 7 0 131072 131069 PO- /dbs_tmp/tmp07.dbf 14cfddf0 19 7 0 131072 131069 PO- /dbs_tmp/tmp08.dbf 17 active, 2047 maximum ========================== понятно, что dbexport..... что диск менять. а чем тут должно помочь зеркалирование? которое средствами информикса, вроде бы включено? да, эти сказевники висят на рейде - просто замена одного диска, автоматом оно должно все восстановить? какие манипуляции-то с ним делать? ... |
| 22.12.2004, 16:59 |
Что-то странно - первичный чанк не читается, а помечен как онлайн, а вторичный помечен как даун. 14d0c490 4 3 0 768000 49 PO- /dbs_pri/dbname2/work01.dbf 1538d188 4 3 0 768000 0 MD- /dbs_mir/dbname2/work01.dbf Я бы попробовал 1. остановить зеркалирование чанка Taking Down a Mirrored Chunk with the onspaces Utility You can use the onspaces utility to take down a chunk. The following example takes down a chunk that is part of the dbspace db_acct: % onspaces -s db_acct -p /dev/mirror_chk1 -o 0 -D For a full description of the onspaces syntax, see “onspaces: Manage Database Spaces” on page 35-48. 2. заменить диск, восстановить линк на него 3. попытаться восстановить вторичный чанк из первичного Recovering a Mirrored Chunk with onspaces You can also use the onspaces utility to recover a down chunk. For example, to recover a chunk that has the pathname /dev/mirror_chk1 and an offset of 0 kilobytes, issue the following command: % onspaces -s db_acct -p /dev/mirror_chk1 -o 0 -O Кстати, было бы неплохо посмотреть ошибки генерируемые ontape Читать по теме - Admin guide, нлава "Using mirrors" ... |
| 22.12.2004, 21:44 |
проверила чанк зеркальный на поломанный основной # dd if=/dbs_mir/dbname2/work01.dbf of=/dev/null bs=2k count=768000 dd: /dbs_mir/dbname2/work01.dbf: Input/output error 250874+0 records in 250874+0 records out не весело, аднака. ... |
| 23.12.2004, 12:14 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1609133]: |
37ms |
67ms |
| others: | 265ms |
| total: | 413ms |
