Помогите востановить сервак
1. Ето сказал сервер 08:55:56 Checkpoint Completed: duration was 0 seconds. 08:56:03 Physical Restore of s_00_calc started. 09:08:25 Checkpoint Completed: duration was 0 seconds. 09:20:52 Checkpoint Completed: duration was 0 seconds. 13:25:05 Checkpoint Completed: duration was 0 seconds. 13:25:07 Physical Restore of s_00_calc Completed. 13:25:08 Checkpoint Completed: duration was 0 seconds. 13:25:09 Logical Log 16755 - Backup Started 13:25:09 Logical Log 16755 Complete. 13:25:11 Logical Log 16755 - Backup Completed 13:25:11 Logical Recovery Started. 13:25:11 Start Logical Recovery - Start Log 16635, End Log 16755 13:25:11 Starting Log Position - 16635 0x1e018 13:25:11 Checkpoint Completed: duration was 0 seconds. 13:26:41 Assert Failed: No Exception Handler 13:26:41 Informix Dynamic Server Version 7.31.TC6 13:26:41 Who: Session(24, informix@netfire, 0, 0) Thread(74, xchg_2.0, 0, 4) Exception at Addr: 0x5863a1, TOS: 0x5983fd90, FP:0x5983feac, Exc: c0000005 13:26:41 Results: Exception Caught. Type: MT_EX_OS, Context: mem 13:26:41 Action: Please notify Informix Technical Support. 13:26:44 Releasing server from system block 13:26:54 See Also: af.432b5e1 13:26:54 , line -1, thread 74, proc id 153, No Exception Handler. 13:26:54 PANIC: Attempting to bring system down 2. Ето сказал on_bar 2005-10-02 08:56:02 390 410 D:\INFORMIX\bin\onbar_d -r s_00_calc 2005-10-02 08:56:05 390 410 Successfully connected to Storage Manager. 2005-10-02 08:56:05 390 410 Begin warm level 0 restore s_00_calc. 2005-10-02 13:25:07 390 410 Completed warm level 0 restore s_00_calc. 2005-10-02 13:25:07 390 410 Begin backup logical log 16755. 2005-10-02 13:25:08 390 410 Successfully connected to Storage Manager. 2005-10-02 13:25:11 390 410 Completed backup logical log 16755. 2005-10-02 13:25:27 390 410 Successfully connected to Storage Manager. 2005-10-02 13:25:37 390 410 Begin restore logical log 16635. 2005-10-02 13:26:55 390 410 ERROR: Unable to write restore data to the database server: \tristarm\archive\buc_fe.c : Archive API processing failed at line 846 for msgtype. Подскажите пожалуйста что делать в таких случиях ??? ... |
| 05.10.2005, 15:33 |
Перезагрузить комп и повторить восстановление... ... |
| 05.10.2005, 16:06 |
vasilisПерезагрузить комп и повторить восстановление... не помагает ... |
| 05.10.2005, 16:39 |
А зачем вы бросились восстанавливаться ? Сервер что, упал и больше не поднимался ? Покажите логи после падения. ... |
| 05.10.2005, 21:02 |
vybegalloА зачем вы бросились восстанавливаться ? Сервер что, упал и больше не поднимался ? Покажите логи после падения. У них сдох винт. ... |
| 06.10.2005, 08:58 |
LOTOS vasilisПерезагрузить комп и повторить восстановление... не помагает Ошибка на том же самом месте и того же типа ? Журавлев ДенисУ них сдох винт. А с чего это видно ? Особенно после того, как завершилось восстановление и начали накатываться логи... И это повторяется два раза... Ошибки вв/выв обычно выглядят по другому, IMHO. ... |
| 06.10.2005, 11:59 |
vasilisА с чего это видно ? Они мне в аське написали: сдох винт, его заменили, файлы чанков создали, пытаются восстановить, а у них "Archive API processing failed at line 846 for msgtype". Я плохо разбираюсь в onbar и вообще бакапрекавери поэтому послал в техподдержку и в форум. ... |
| 06.10.2005, 12:16 |
Чего же он сразу то не сказал, ведь предусловия каждой ошибки очень важны ? В таком случае очень вероятно, что при воссоздании чанков была допущена ошибка или в размере чанка или (исходя из того, что свалилось на логическом восстановлении) нет нужного темпового пространства или логи должны быть в другом пространстве и т.п. ... |
| 06.10.2005, 14:42 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1608878]: |
51ms |
57ms |
| others: | 199ms |
| total: | 356ms |
