Обновилась статья по обработке дат в IDS
Date processing in Informix Dynamic Server Let's make a date Level: Introductory Jacques Roy (jacquesr@us.ibm.com), Technical Lead, IBM 13 Oct 2005 Updated 22 Dec 2005 IBM® Informix® Dynamic Server has several functions that manipulate date and datetime types. You can exploit these functions to provide better processing and analysis of your business data. You can also add new functions that will simplify the solution of some date-based business problems. This updated version reflects some date processing related to the ISO 8601 standard. The standard-compliant functions were originally written by Jonathan Leffler as stored procedures. Their conversion to functions was a trivial task... http://www-128.ibm.com/developerworks/db2/library/techarticle/dm-0510roy/index.html ... |
| 31.01.2006, 20:29 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1608766]: |
36ms |
30ms |
| others: | 207ms |
| total: | 322ms |
