install IDS10 and ISM
После установки, получаю такой лог инициализации ISM ism_startup is starting the ISM daemons ism_startup is initializing the ISM Server created resource id 80.0.84.15.141.211.143.69.192.168.168.213(1) created resource id 81.0.84.15.141.211.143.69.192.168.168.213(1) create failed: `K' and `rill-mobile' are not the same type create failed: 'ISMDiskData' invalid choice for 'label template' created resource id 82.0.84.15.141.211.143.69.192.168.168.213(1) created resource id 83.0.84.15.141.211.143.69.192.168.168.213(1) create failed: `K' and `rill-mobile' are not the same type create failed: 'ISMDiskLogs' invalid choice for 'label template' created resource id 84.0.84.15.141.211.143.69.192.168.168.213(1) created resource id 85.0.84.15.141.211.143.69.192.168.168.213(1) create failed: `K' and `rill-mobile' are not the same type create failed: 'ISMData' invalid choice for 'label template' created resource id 86.0.84.15.141.211.143.69.192.168.168.213(1) created resource id 87.0.84.15.141.211.143.69.192.168.168.213(1) create failed: `K' and `rill-mobile' are not the same type create failed: 'ISMLogs' invalid choice for 'label template' created resource id 88.0.84.15.141.211.143.69.192.168.168.213(1) created resource id 89.0.84.15.141.211.143.69.192.168.168.213(1) create failed: `K' and `rill-mobile' are not the same type create failed: 'ISMData Clone' invalid choice for 'label template' created resource id 90.0.84.15.141.211.143.69.192.168.168.213(1) created resource id 91.0.84.15.141.211.143.69.192.168.168.213(1) create failed: `K' and `rill-mobile' are not the same type create failed: 'ISMLogs Clone' invalid choice for 'label template' created resource id 92.0.84.15.141.211.143.69.192.168.168.213(1) group: Default; group: ISMDiskData; group: ISMDiskLogs; group: ISMData; group: ISMLogs; group: ISMData Clone; group: ISMLogs Clone; updated resource id 55.0.84.15.141.211.143.69.192.168.168.213(15) updated resource id 81.0.84.15.141.211.143.69.192.168.168.213(12) updated resource id 83.0.84.15.141.211.143.69.192.168.168.213(10) updated resource id 85.0.84.15.141.211.143.69.192.168.168.213(8) updated resource id 87.0.84.15.141.211.143.69.192.168.168.213(6) updated resource id 89.0.84.15.141.211.143.69.192.168.168.213(4) updated resource id 91.0.84.15.141.211.143.69.192.168.168.213(2) ism_startup: Configure devices manually using ism_add. Done. Соответсвенно не видит пулов ISMDiskData... Занимался настройкой по доке http://ln.com.ua/~openxs/projects/informix/ids003.htm но при разметке томов получил ошибку, что нет такого пула. Ветку http://www.sql.ru/forum/actualthread.aspx?tid=93726 читал, но ism_stattup -init даёт тоже самое ОС XP prof, имя компа - kirill-mobile Содержимое daemon.log 12/25/06 16:35:18 nsrd: server notice: started 12/25/06 16:35:19 nsrck: index for kirill-mobile is created. 12/25/06 16:35:30 nsrmmdbd: media db is cross checking the save sets 12/25/06 16:35:31 nsrmmdbd: media db is open for business 12/25/06 16:35:31 nsrindexd: checking index for kirill-mobile 12/25/06 16:35:31 nsrd: index notice: completed checking 1 client(s) 12/25/06 16:35:32 nsrindexd: completed checking 1 client(s) 12/25/06 16:35:40 nsrd: License Summary (No Enterprise Enabled): 12/25/06 16:35:40 nsrd: Available: sv=1, ws=0, clu=0, borrowed=0 12/25/06 16:35:40 nsrd: Remaining: sv=1, ws=0, clu=0 Содержимое nsrjb.res administrator: Администраторы@kirill-mobile; fields: kirill_mobile, 001-999; name: Default; next: kirill_mobile.001; separator: .; type: NSR label; resource identifier: 58.0.84.15.141.211.143.69.192.168.168.213(2) administrator: Администраторы@kirill-mobile; fields: kirill_mobile_c, 001-999; name: Default Clone; next: kirill_mobile_c.001; separator: .; type: NSR label; resource identifier: 59.0.84.15.141.211.143.69.192.168.168.213(2) administrator: Администраторы@kirill-mobile; fields: kirill_mobile, 001-999, a-b; name: Two Sided; next: kirill_mobile.001.a; separator: .; type: NSR label; resource identifier: 60.0.84.15.141.211.143.69.192.168.168.213(2) administrator: Администраторы@kirill-mobile; fields: kirill_mobile, archive, 001-999; name: Archive; next: kirill_mobile.archive.001; separator: .; type: NSR label; resource identifier: 61.0.84.15.141.211.143.69.192.168.168.213(2) administrator: Администраторы@kirill-mobile; fields: kirill_mobile_c, archive, 001-999; name: Archive Clone; next: kirill_mobile_c.archive.001; separator: .; type: NSR label; resource identifier: 62.0.84.15.141.211.143.69.192.168.168.213(2) administrator: Администраторы@kirill-mobile; fields: kirill_mobile, pcarchive, 001-999; name: PC Archive; next: kirill_mobile.pcarchive.001; separator: .; type: NSR label; resource identifier: 63.0.84.15.141.211.143.69.192.168.168.213(2) administrator: Администраторы@kirill-mobile; fields: kirill_mobile_c, pcarchive, 001-999; name: PC Archive Clone; next: kirill_mobile_c.pcarchive.001; separator: .; type: NSR label; resource identifier: 64.0.84.15.141.211.143.69.192.168.168.213(2) administrator: Администраторы@kirill-mobile; fields: Full, 001-999; name: Full; next: Full.001; separator: .; type: NSR label; resource identifier: 65.0.84.15.141.211.143.69.192.168.168.213(2) administrator: Администраторы@kirill-mobile; fields: NonFull, 001-999; name: NonFull; next: NonFull.001; separator: .; type: NSR label; resource identifier: 66.0.84.15.141.211.143.69.192.168.168.213(2) administrator: Администраторы@kirill-mobile; fields: Offsite, 001-999; name: Offsite; next: Offsite.001; separator: .; type: NSR label; resource identifier: 67.0.84.15.141.211.143.69.192.168.168.213(2) ... |
| 25.12.2006, 16:54 |
Не вдаваясь в подробности приведенного лога, могу сказать только одно. По указаннму доку ISM настраивался не один раз - если выполнять все точно как там написанно, то все работает без проблем. Могу предположить не точность в исполнении указанных инструкций. Как грица, "...тщательнЕе надо, тщательнЕе...". ... |
| 25.12.2006, 22:10 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1608492]: |
159ms |
53ms |
| others: | 256ms |
| total: | 519ms |
