проблема с транзакциями
Спасибо, нашел того клиента который держал базу. Вывожу команду set ALLUSERSPROFILE=C:\Documents and Settings\All Users APPDATA=C:\Documents and Settings\informix.ZAPAS.000\Application Data CLASSPATH=C:\PROGRA~1\informix\extend\krakatoa\krakatoa.jar;C:\PROGRA~1\informix\extend\kr akatoa\jdbc.jar; CLIENTNAME=Console CLIENT_LOCALE=ru_RU.CP1251 ClusterLog=C:\WINDOWS\Cluster\cluster.log CommonProgramFiles=C:\Program Files\Common Files COMPUTERNAME=ZAPAS ComSpec=C:\WINDOWS\system32\cmd.exe DBDATE=DMY4. DBLANG=EN_US.CP1252 DBMONEY=. DBTEMP=C:\PROGRA~1\informix\infxtmp DB_LOCALE=ru_RU.CP1251 FP_NO_HOST_CHECK=NO HOMEDRIVE=C: HOMEPATH=\Documents and Settings\informix.ZAPAS.000 INFORMIXDIR=C:\PROGRA~1\informix INFORMIXSERVER=rs INFORMIXSQLHOSTS=\\XEO LOGONSERVER=\\ZAPAS NUMBER_OF_PROCESSORS=2 ONCONFIG=ONCONFIG.rs OS=Windows_NT Path=C:\PROGRA~1\informix\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\p rogram files\intel\ServerManager\Server\BIN;C:\program files\intel\ServerManager\cli;C:\To ols;C:\TOOLS;C:\Program Files\Informix\bin;C:\Program Files\Java\j2re1.4.2_04 PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH PROCESSOR_ARCHITECTURE=x86 PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 3, GenuineIntel PROCESSOR_LEVEL=15 PROCESSOR_REVISION=0403 ProgramFiles=C:\Program Files PROMPT=$P$G SERVER_LOCALE=ru_RU.CP1251 SESSIONNAME=Console SystemDrive=C: SystemRoot=C:\WINDOWS TEMP=C:\DOCUME~1\INFORM~1.000\LOCALS~1\Temp TMP=C:\DOCUME~1\INFORM~1.000\LOCALS~1\Temp USERDOMAIN=ZAPAS USERNAME=informix USERPROFILE=C:\Documents and Settings\informix.ZAPAS.000 windir=C:\WINDOWS ... |
| 19.07.2007, 11:03 |
dima312 CLIENT_LOCALE=ru_RU.CP1251 DBDATE=DMY4. DBLANG=EN_US.CP1252 DBMONEY=. DBTEMP=C:\PROGRA~1\informix\infxtmp DB_LOCALE=ru_RU.CP1251 INFORMIXDIR=C:\PROGRA~1\informix INFORMIXSERVER=rs INFORMIXSQLHOSTS=\\XEO ONCONFIG=ONCONFIG.rs Path=C:\PROGRA~1\informix\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\program files\intel\ServerManager\Server\BIN;C:\program files\intel\ServerManager\cli;C:\To ols;C:\TOOLS;C:\Program Files\Informix\bin;C:\Program Files\Java\j2re1.4.2_04 SERVER_LOCALE=ru_RU.CP1251 USERDOMAIN=ZAPAS USERNAME=informix Переменную, выделенную жирным шрифтом, нужно убрать (оставить по умолчанию), так как у вас, скорее всего, нет этих файлов. Переменные, выделенные курсивом, вызывают подозрение (настройки сервера - ветка SQLHOSTS берутся не с локального компа, а из сети и там может быть все что угодно. Лучше настроить через setnet32 на локальном компе и брать с локального реестра.) Еще совет - никогда не ставить клиента в Program Files, а лучше делать это в отдельный каталог, типа c:\informix, чтобы не было такого INFORMIXDIR=C:\PROGRA~1\informix (были ньюансы :) И просмотрите, есть ли у вас файлы по следующему пути C:\Program Files\informix\gls\lc11\ru_ru\*.* ? ... |
| 19.07.2007, 17:38 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1608351]: |
140ms |
53ms |
| others: | 218ms |
| total: | 463ms |
