New features in Informix 4GL 7.50.xC2
Несмотря на кризис появляются новые версии Информикса New features in Informix 4GL 7.50.xC2 With IBM Informix 4GL 7.50.xC2, you can deploy your 4GL functions on the Web without rewriting any source code. The w4gl utility uses your existing 4GL code to create Web services. These Web services can be used by, for example, Java and .Net applications on the Web without you doing any Java or .NET programming. Your business logic is maintained in 4GL, and made available to a variety of Web clients by the Web services. С уважением, Виктор ... |
| 25.12.2008, 10:01 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1607926]: |
53ms |
25ms |
| others: | 241ms |
| total: | 366ms |
