SDS - Blocked:CKPT
Никто не встречался с ситуацией: 11.50.FC5 после инициализации SDS при первой же контрольной точке виснет SDS сервер IBM Informix Dynamic Server Version 11.50.FC5 -- Read-Only (SDS) (CKPT REQ) -- Up 00:06:07 -- 970649 Kbytes Blocked:CKPT ну и соответственно чуток позже основной отключает SDS ... |
| 10.08.2009, 12:01 |
SDS - Blocked:CKPT
Что в логах на первичке и вторичке? ... |
| 10.08.2009, 12:23 |
SDS - Blocked:CKPT
А с сетью все в порядке ? ... |
| 10.08.2009, 15:58 |
SDS - Blocked:CKPT
С сетью все в порядке. Вот лог с SDS: 16:20:49 IBM Informix Dynamic Server Started. 16:20:49 Requested shared memory segment size rounded from 1141760KB to 1146880KB 16:20:49 Shared memory segment will use large pages with intimate shared memory (ISM) if available 16:20:51 Segment locked: addr=10a000000, size=1174405120 16:20:51 Requested shared memory segment size rounded from 1600000KB to 1600512KB Mon Aug 10 16:20:52 2009 16:20:52 Warning: ONCONFIG dump directory (DUMPDIR) '/var/log/informix/tmp' has insecure permissions 16:20:52 Event alarms enabled. ALARMPROG = '/opt/informix/11.50fc5/etc/no_log.sh' 16:20:52 Booting Language <c> from module <> 16:20:52 Loading Module <CNULL> 16:20:52 Booting Language <builtin> from module <> 16:20:52 Loading Module <BUILTINNULL> 16:20:52 SQLTRACE: SQL History Tracing set to 1000 SQL statements. 16:20:57 DR: DRAUTO is 0 (Off) 16:20:57 DR: ENCRYPT_HDR is 0 (HDR encryption Disabled) 16:20:57 Fast poll /dev/poll enabled. 16:20:58 IBM Informix Dynamic Server Version 11.50.FC5 Software Serial Number AAA#B000000 16:21:00 Setting checkpoint 3856932:92018 intvl:20769 16:21:00 SDS Server idssds1 - state is now connected 16:21:02 IBM Informix Dynamic Server Initialized -- Shared Memory Initialized. 16:21:02 Started 2 B-tree scanners. 16:21:02 B-tree scanner threshold set at 5000. 16:21:02 B-tree scanner range scan size set to -1. 16:21:02 B-tree scanner ALICE mode set to 6. 16:21:02 B-tree scanner index compression level set to med. 16:21:02 Requesting logs from 3856932:92 16:21:02 Initializing SDS Temp dbspace tempsds2 16:21:02 Dataskip is now OFF for all dbspaces 16:21:02 Restartable Restore has been ENABLED 16:21:02 Recovery Mode 16:21:03 Logical Recovery Started. 16:21:03 10 recovery worker threads will be started. 16:21:03 B-tree scanners disabled. 16:21:03 Start Logical Recovery - Start Log 3856932, End Log ? 16:21:03 Starting Log Position - 3856932 0x92018 16:21:04 DR: SDS secondary server operational 16:21:04 Started processing open transactions on secondary during startup 16:21:04 Checkpoint Completed: duration was 0 seconds. 16:21:04 Mon Aug 10 - loguniq 3856932, logpos 0x92018, timestamp: 0xa18db2a5 Interval: 20768 16:21:04 Maximum server connections 0 16:21:04 Finished processing open transactions on secondary during startup. 16:21:40 Logical Log 3856932 Complete, timestamp: 0xa18db2a7. 16:22:21 Checkpoint Statistics - Avg. Txn Block Time 0.000, # Txns blocked 0, Plog used 14, Llog used 0 16:27:49 SDS: Received Shutdown request from idssds1, Reason: The SDS server was shut down because the timeout period, se SDS_TIMEOUT configuration parameter, was exceeded. 16:27:49 DR:Shutting down the server. т.е. сервер стартонул, даже переход на след лог отобразился и на к.т. завис вот лог с первичного: 16:20:56 Maximum server connections 0 16:20:56 Checkpoint Statistics - Avg. Txn Block Time 0.000, # Txns blocked 0, Plog used 22, Llog used 66 16:20:58 SDS Server idssds2 - state is now connected 16:21:36 Logical Log 3856932 Complete, timestamp: 0xa18db236. 16:22:18 Checkpoint Completed: duration was 1 seconds. 16:22:18 Mon Aug 10 - loguniq 3856933, logpos 0x5018, timestamp: 0xa18db73f Interval: 20769 16:22:18 Maximum server connections 0 16:22:18 Checkpoint Statistics - Avg. Txn Block Time 0.000, # Txns blocked 0, Plog used 12, Llog used 12 16:27:12 Logical Log 3856933 Complete, timestamp: 0xa18db745. 16:27:45 ERROR: Removing SDS Node idssds2 has timed out - removing 16:27:45 Checkpoint Completed: duration was 16 seconds. 16:27:45 Mon Aug 10 - loguniq 3856934, logpos 0x5018, timestamp: 0xa18db782 Interval: 20770 16:27:45 Maximum server connections 0 16:27:45 Checkpoint Statistics - Avg. Txn Block Time 0.000, # Txns blocked 0, Plog used 11, Llog used 10 16:27:45 SDS Server idssds2 - state is now disconnected Сделал обращение на саппорт. ... |
| 10.08.2009, 17:01 |
SDS - Blocked:CKPT
Какое значение параметра SDS_TIMEOUT на первичке? Если слишком маленькое, то рекомендация - увеличить. ... |
| 10.08.2009, 18:27 |
SDS - Blocked:CKPT
50 в результате манипуляций получилось (как по мне - огромное) Какое по вашему слишком малое значение? -это все относительно. Есть любители указать в документации расплывчато - если мало - увеличить. но вот редко кто раскрывает что такое - малое или большое значение. В реальности у меня минимальное значение получалось около 10 сек. (м.б. и меньше но я с 5 сразу увеличил до 10) при 5 СДС не успевал проиницилизироваться и установить СДС режим. При этих же парараметрах СДС некоторое время работало. Даже успели протестировать переход туда-назад. Все было как грят ОК. Но, после обновления данных с архива - как в классике "... все пропало". Проявляться начало на FC4 на FC5 єто уже по ходу решения проблемы перешли. Да и прикол то в том, что СДС у меня без разрешения транзакций, т.е. в момем понимании проблемы как таковой не должно быть. ... |
| 11.08.2009, 00:17 |
SDS - Blocked:CKPT
В IIUG встречалась рекомендация SDS_TIMEOUT=500. ... |
| 11.08.2009, 10:23 |
SDS - Blocked:CKPT
У кото-то работает SDS c отрицательным sh_stamp на Primary ? echo "set isolation to dirty read ; select sh_stamp from sysshmvals" | dbaccess sysmaster ... |
| 13.08.2009, 10:05 |
SDS - Blocked:CKPT
Вернее даже не с отрицательным, а с большим - типа -1579784313 снова же - сказали большое, а не уточнили какое значение считать большим. ... |
| 13.08.2009, 11:08 |
SDS - Blocked:CKPT
Все, тему вроде как можно считать закрытой. проявление APAR number IC62441 Будет исправлен в 11.50хС6 либо в каком-то фиксе. Везет мне последние время на баги инфомикса. ... |
| 13.08.2009, 11:28 |
SDS - Blocked:CKPT
zaietsВсе, тему вроде как можно считать закрытой. проявление APAR number IC62441 Будет исправлен в 11.50хС6 либо в каком-то фиксе. Везет мне последние время на баги инфомикса. Собирай статистику "чётных" и "нечётных" версий :) ... |
| 23.08.2009, 20:28 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1607749]: |
33ms |
56ms |
| others: | 209ms |
| total: | 347ms |
