How to generate schema for storage spaces
How to generate schema for storage spaces ? Starting with Informix 11.70, the dbschema utility now can generate the schema of storage spaces, chunks, and physical and logical logs. Run the following command to generate an output file named dbschema.out that contains the commands for reproducing the storage spaces, chunks, physical logs, and logical logs in onspaces and onparams utility format: >dbschema -c -ns dbschema.out Regardless of the situation, it.s a good idea to generate and keep a copy of storage schema output, which can save time and effort in case of a disaster. Insider #126: Holiday Greetings - https://mail.google.com/mail/?hl=ru&shva=1#inbox/12d49eacdea22a44 Прикольно .... :) С уважением, Вадим. ... |
| 03.01.2011, 12:33 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1607426]: |
99ms |
34ms |
| others: | 233ms |
| total: | 423ms |
