What's new in version 11.70.xC8
What's new in version 11.70.xC8 of IBM Informix: Migration Server changes Changes to online notes Installation Windows Easier installation of 32-bit programs on Windows 64-bit operating systems Uninstall Informix programs on Windows by using the Control Panel Administration Error handling New event alarm for network failures IBM OpenAdmin Tool (OAT) for Informix Customized help is not available Find what you need by searching OAT Back up and restore Optimize backups for data deduplication Enhanced support for IBM Tivoli Storage Manager features ON-Bar activity log timestamps Configuration Compare onconfig files (UNIX, Linux) Control the duration and frequency of connection attempts Performance Faster operations In-place alter operations on serial data types Dynamic tuning Dynamic private memory caches for CPU virtual processors Application development New syntax for queries Joins with lateral references Foreign-key constraints Temporarily prevent constraint validation Faster creation of foreign-key constraints Basic text searching Enhanced basic text searching New default Defining separators for fractional seconds in date-time values High availability Connection Manager Improvements to Connection Manager Monitoring View log-staging information on RS secondary servers Enterprise Replication Easier setup Simplified schema changes for replicated tables Configuration Control the replication of large objects Custom checksum function for consistency checking Security Connectivity Transport Layer Security (TLS) versions 1.0, 1.1 and 1.2 enabled by default ... |
| 13.01.2014, 14:32:32 |
Чота я эту фишку с LATERAL не понимаю. Нафига она введена, и что дает такого, что нельзя было написать раньше ? https://www.ibm.com/developerworks/community/blogs/c5700ec6-3e26-4ffc-96eb-4eadec8c0c1f/entry/lateral_derived_table_in_informix_12_10_xc2_release?lang=en А вот за IN PLACE ALTER с SERIAL - спасибо. Недавно пришлось делать. ... |
| 13.01.2014, 21:48:56 |
ВыбегаллоЧота я эту фишку с LATERAL не понимаю. Нафига она введена, и что дает такого, что нельзя было написать раньше ? Я так понял, что введено для совместимости со стандартами ISO/ANSI, поскольку уже есть в других БД, точно знаю, есть в Oracle. Требуется, чтобы сделать join во from-е между двумя derived tables (запрос как таблица). Пример из доки: Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. ... |
| 14.01.2014, 11:45:31 |
start [/forum/search_topic.php?author=konaz_714&author_mode=last_posts&do_search=1]: |
79ms |
48ms |
| others: | 711ms |
| total: | 911ms |
