Is it safe to use the same value of SHMBASE for co-existing instances?
FYI ... Is it safe to use the same value of SHMBASE for co-existing instances? http://www-01.ibm.com/support/docview.wss?uid=swg21883513&myns=swgimgmt&mynp=OCSSGU8G&mync=E&cm_sp=swgimgmt-_-OCSSGU8G-_-E Kind regards, Vadim. ... |
| 02.06.2015, 10:25:17 |
start [/forum/topic.php?fid=44&gotonew=1&tid=1606871]: |
186ms |
28ms |
| others: | 200ms |
| total: | 461ms |
