Проверяем базы данных на уязвимость - Guardium Vulnerability Assessment Evaluation Editio
FYI ... Проверяем базы данных на уязвимость - Guardium Vulnerability Assessment Evaluation Edition --- IBM® InfoSphere® Guardium® Vulnerability Assessment Evaluation Edition provides users with an opportunity to preview and evaluate the IBM® InfoSphere® Guardium® Vulnerability Assessment solution using a subset of the full functionality. This free download is enabled for up to 10 data sources and includes a limited version of Guardium Vulnerability Analysis that will enable you to do: 1. Sensitive Data Discovery: - Identify sensitive information like credit card numbers and transactions, or personal financial data - Produce a report with sensitive objects for each inspected server 2. Vulnerability Assessment: - Run predefined tests designed to illustrate common database vulnerability issues. - Produce a Vulnerability Assessment report with a scorecard, and basic results Guardium Vulnerability Assessment Evaluation Edition - https://www14.software.ibm.com/webapp/iwm/web/preLogin.do?source=swg-guardiumva-eval DeveloperWorks - http://www.ibm.com/developerworks/downloads/im/guardiumva/ --- С уважением, Вадим. ... |
| 14.04.2014, 19:51:00 |
Про Informix вот здесь. http://www-01.ibm.com/support/docview.wss?rs=630&uid=swg21670021 http://www-01.ibm.com/support/docview.wss?rs=630&uid=swg21670019 ... |
| 28.04.2014, 11:45:43 |
start [/forum/topic.php?fid=44&fpage=8&tid=1606960]: |
55ms |
40ms |
| others: | 196ms |
| total: | 340ms |
