Странный глюк в Informix Version 9.30.TC2E3
Привет, народ помогите кто чем может. DBA не может выпонить запрос к таблице в другой базе данных из процедуры ??? А resource может :( Пример кода. create database test1; grant resource to user1; grant resource to user2; create database test2; grant resource to user1; grant resource to user2; database test1; set session authorization to "user1"; create table "user1".t1 (id int); grant all on "user1".t1 to "user2" as "user1"; grant all on "user1".t1 to "informix" as "user1"; select * from systabauth a, systables b where a.tabid= b.tabid and b.tabname = 't1'; -- grantor grantee tabid tabauth tabname owner .... -- user1 informix 100 su-idxar- t1 user1 .... -- user1 user2 100 su-idxar- t1 user1 .... insert into "user1".t1 values (1); database test2; set session authorization to "user2"; create procedure "user2".proctest() define v_id int; foreach select id into v_id from test1:"user1".t1 end foreach; end procedure; set session authorization to "informix"; select id from test1:"user1".t1; execute procedure "user2".proctest(); -- [Informix][Dynamic Server plus Universal Data Option][test2] -- SQL Error (-272) : No SELECT permission. ... |
| 19.09.2002, 13:33 |
start [/forum/topic.php?fid=44&fpage=70&tid=1609446]: |
33ms |
25ms |
| others: | 215ms |
| total: | 324ms |
