AIX +INFORMIX
Нужно ли компилировать ядро при установке Informix 9.4 на AIX? Как это делать? Установил IDS 9.4 без компиляции. Demo база подымаеться, но при запросе dbaccessdemo store_demo возникает ошибка. The type of your terminal is unknown to the system Какой терминал ему нужен ??? Поигрался с переменными TERM TERMCAP, пока ничего не получилось. Помогите. ... |
| 10.02.2005, 21:06 |
AIX +INFORMIX
INFORMIXTERM The INFORMIXTERM environment variable specifies whether 4GL should use the information in the termcap file or the terminfo directory. INFORMIXTERM determines terminal-dependent keyboard and screen capabilities such as the operation of function keys, color and intensity attributes in screen displays, and the definition of window border and graphics characters. If INFORMIXTERM is not set, the default setting is termcap. When 4GL is installed on your system, a termcap file is placed in the etc subdirectory of $INFORMIXDIR. This file is a superset of an operating system termcap file. You can use the termcap file supplied by Informix, the system termcap file, or a termcap file that you created yourself. You must set the TERMCAP environment variable if you do not use the default termcap file. The terminfo directory contains a file for each terminal name that has been defined. It is supported only on machines that provide full support for the UNIX System V terminfo library. For details, see the Version 6.0 on-line machine notes for your machine. Set the INFORMIXTERM environment variable to terminfo as follows: C shell: setenv INFORMIXTERM terminfo Bourne shell: INFORMIXTERM=terminfo export INFORMIXTERM Set the INFORMIXTERM environment variable to termcap as follows: C shell: setenv INFORMIXTERM termcap Bourne shell: INFORMIXTERM=termcap export INFORMIXTERM Note: If INFORMIXTERM is set to termcap, you must set the UNIX environment variable TERMCAP; if INFORMIXTERM is set to terminfo, you must set the UNIX environment variable TERMINFO. setenv INFORMIXTERM terminfo termcap ... |
| 10.02.2005, 22:03 |
AIX +INFORMIX
Попробуй значения переменных export TERM=vt100 export TERMCAP=$INFORMIXDIR/etc/termcap ... |
| 11.02.2005, 09:05 |
AIX +INFORMIX
Идем дальше. при создании индекса на большой таблице получаем IBM Informix Dynamic Server Version 9.40.FC6 -- On-Line -- Up 1 days 22:48:39 -- 1251456 Kbytes PDQ Priority set. 212: Cannot add index. 28: No space left on device Error in line 4 Near character position 25 в таблице ~60 000 000 записей, фрагментирована на 12 частей, строю уникальный индекс по полю типа serial . Места достаточно. темпаков тоже полно. Пробовал фрагментировать индекс не помогает. Все лежит в raw. создавлось через /usr/sbin/mklv -y ifmx_chunck aix_volume 4G какие будут рекомендации? ... |
| 14.02.2005, 13:01 |
AIX +INFORMIX
А помониторить где именно места не хватило (onstat -d в момент построения индекса)? И вообще зачем задавать новый вопрос в старой нитке?. Имхо tempdbs весь откушался. ... |
| 14.02.2005, 13:22 |
AIX +INFORMIX
Что то подобное уменя было раньше при неверных значениях DBSPACETEMP из ONCONFIGa DBTEMP из ENVIRONMENTa Тогда при построении индекса, рос файл в одной из файловых систем. Посмотри как уменьшается свободное место в файловой системе при построении индекса . ... |
| 14.02.2005, 14:42 |
AIX +INFORMIX
У меня как-то при трех описанных в DBSPACETEMP спэйсах, из которых реально существовало только 2, в качестве темп использовался rootdb. Проблема исчезла после исправления DBSPACETEMP и перезагрузки. ... |
| 14.02.2005, 17:01 |
start [/forum/topic.php?fid=44&fpage=61&tid=1609100]: |
55ms |
62ms |
| others: | 257ms |
| total: | 436ms |
