Средства администрирования.
Подскажите пожалуйста где можна взять средства администрирования IDS (ON-Monitor, Cockpit и т.д.). ... |
| 03.01.2006, 14:10 |
Все я уже достал! ... |
| 04.01.2006, 12:03 |
Что, достал ON-Monitor и Cockpit для Windows-платформы ? Что то не верится, т.к. их здесь никогда не было :) А по средствам администрирования IDS читать FAQ http://www.sql.ru/faq/faq_topic.aspx?fid=522 ... |
| 05.01.2006, 17:23 |
Какой то новый (для меня, по крайней мере) тулз для администрирования IDS "I use ServerStudio as a developer, not as a DBA. DBAs may also want to give a try to IIUG sponsor CobraSonic's tools http://www.cobrasonic.com/ " (Jean Georges Perrin) Вот краткая информация по этому набору, которую я хочу поместить в FAQ. --------------------------------- CobraSonic's tools http://www.cobrasonic.com/eng/prd/prd_main.jsp http://www.cobrasonic.com/ Cobrasonic Software Inc. (бывшая CobraTech Inc.) http://www.cobrasonic.com/index_eng.jsp IIUG is sponsor CobraSonic's tools. Supported IDS Versions - 7.x / 9.x / 10.x - DBSonar http://www.cobrasonic.com/eng/prd/prd_main.jsp?prodid=2 continuously monitors database systems for potential problems and issues precautious alerts for you to solve these problems before they impact end-users. It also provides analyses and suggestions with real-time/historical resource consumption data, allowing system administrators to make informed decisions in handling exceptions or planning resources. With DBSonar, it's like having a 24x7 Informix database expert with you. - Fatal event monitoring and alerting - Real-time system monitoring - Configuartion support for IDS & OS - Performance analysis and suggestions for improvements - Capacity planning DBSonar supports IDS 7.x, 9.x and 10.x on Unix(s) and Linux platform. Downloads (Trial Version по состоянию на 1006-01-31): DBSonar Server for Informix Database DBSonarServer4.7.AIX.5.2.64BIT.TRIAL.tar.gz Server for AIX 5.2 and above DBSonarServer4.7.Linux.32BIT.TRIAL.tar.gz Server for Linux 2.6 DBSonarServer4.7.SunOS.64BIT.TRIAL.tar.gz Server for Solaris 8 and above DBSonarServer4.7.HPUX.64BIT.TRIAL.tar.gz Server for HPUX 11.x (PA-RISC) DBSonar Front-end for Informix Database DBSonarClient4.7.Windows.zip Front-end for MS-Windows - DBOrg http://www.cobrasonic.com/eng/prd/prd_main.jsp?prodid=1 offers a complete solution for database space management and reorganization. Multiple database systems can be centrally managed from a single console, which provides optimized online/pre-scheduled disk space reorganization and capacity planning. - On-line database re-organization - Re-organization based on predefined schedule - DBExpert Enterprise http://www.cobrasonic.com/eng/prd/prd_main.jsp?prodid=3 quantifies and categorizes all operational information for database servers and database systems. With graphical user interface and helpful suggestions, it enables system administrators to easily manage and fine-tune enterprise database systems. It is a comprehensive database system management solution for checking correctness and consistency of database tables, detecting system table anomalies, and improving daily operational efficiencies. - DBOrg - DBSonar - Adschema Database Schema Generator - AdPLoad High-performance parallel data loading - AdDBGuard Database Table Structure Detection - AdDataGuard Table Content Comparison - DBTS The Best Real-Time Text Search Engine for Informix http://www.cobrasonic.com/eng/prd/prd_main.jsp?prodid=5 ------------------------------------------------------------- ... |
| 31.01.2006, 18:50 |
vasilisКакой то новый (для меня, по крайней мере) тулз для администрирования IDS ..... DBSonar Client MS-Windows 4.7 42.7 MB Мощно, или там jre засунута, но тогда почему только под win, или ... видеоролики? Щаз качнем ... |
| 01.02.2006, 10:09 |
Журавлев Денис DBSonar Client MS-Windows 4.7 42.7 MB Мощно, или там jre засунута, но тогда почему только под win, или ... видеоролики? Щаз качнемИ вправду jre занимает 48 метров. ... |
| 01.02.2006, 14:06 |
Журавлев Денис Журавлев Денис DBSonar Client MS-Windows 4.7 42.7 MB Мощно, или там jre засунута, но тогда почему только под win, или ... видеоролики? Щаз качнемИ вправду jre занимает 48 метров. Во дают, для объема могли и операционку присандалить :) А JRE хоть какой версии ? И что из себя продукт представляет ? ... |
| 02.02.2006, 13:30 |
start [/forum/topic.php?fid=44&fpage=53&tid=1608765]: |
124ms |
49ms |
| others: | 197ms |
| total: | 412ms |
