добавление пользователей
Здрасте всем, может вопрос глупый, но нигде не нашел как это делается - как в informixe добавить пользователя . ... |
| 18.03.2004, 09:52 |
Добавлять пользователей надо средствами операционной системы. Пользователь Informix - это пользователь ОС, возможно (если установка была с разделением ролей), принадлежащий к определенной группе. Такие дела. ... |
| 18.03.2004, 10:40 |
Create user в Informix ... |
| 18.03.2004, 11:48 |
OK, спасибо - это я понял а подскажите, плз еще вот такую тему - -956 Client client-name or user is not trusted by the database server. informix стоит на NT где это надо прописывать ? ... |
| 18.03.2004, 12:19 |
finderr -956 -956 Client client-name is not in /etc/hosts.equiv on the remote host. This operation cannot be completed because the specified remote computer does not recognize the name of the client computer (the local host, whose name the hostname command returns). Client names are normally recorded in the configuration file /etc/hosts.equiv. The rhosts file on the remote computer might also need modification. For more information on these files and the relation between them, try man rhosts on a UNIX system. See the remote host administrator to ensure that the client host name is specified in /etc/hosts.equiv file for the remote host. This message appears in versions prior to Version 6.0. -956 Client client-name or user is not trusted by the database server. The desired database server does not consider the client computer or your user ID trusted. Ask the system administrator to include the client computer as a trusted host and/or your user id as a trusted user in the /etc/hosts.equiv file on the server computer or in the .rhosts file in your home directory on the server computer. See the UNIX manual pages on HOSTS.EQUIV(5) for more information. Alternatively, you can explicitly specify your user name and password in the USER clause of a CONNECT statement or in the .netrc file in your home directory on the client computer. See the Informix Guide to SQL: Syntax for information on the CONNECT statement, and the UNIX manual pages regarding NETRC(5) for information on the .netrc file. This message appears with Version 6.0 and later. ... |
| 18.03.2004, 13:39 |
Для NT hosts.equiv должен лежать где-то в WinNT\system32\drivers\etc ... |
| 18.03.2004, 13:45 |
ага, только в NT такого понятия как hosts.equiv нет (имхо нет), - файла такого тем более нету, отсюда и вопрос где надо разрешать хосту ходить в базу ? может тут есть кто, у кого Informix на NT стоит ? подскажите ... |
| 18.03.2004, 13:55 |
Ты понял что hosts.equiv необходим что бы пользователь мог пройти без пароля? на win создай сам этот файлик в \system32\drivers\etc ... |
| 18.03.2004, 14:34 |
создавать такой файл уже пробовал - не помогает..... ... |
| 18.03.2004, 17:06 |
Значит неправильно создал. Формат внутри там специфический. Но не очень понятно, зачем же так секьюрити пренебрегать ? Неужели трудно завести в НТ пользователя с паролем, под которым клиент коннектиться к серверу ? ... |
| 18.03.2004, 17:49 |
в том то и дело, что пользователь есть и пароль у него есть, и с самого сервера я под ним могу зайти в базу, а когда с другого компа, то получаю сообщение -956 Client client-name or user is not trusted by the database server. а законнектится оочень надо в чем может быть дело ? ... |
| 19.03.2004, 10:22 |
Судя по всему проблемы с настройками клиентской части informix-а на 2-м компе. Посмотри под каким пользователем ты пытаешся прорваться в логе сервера. Для быстрой проверки правильности настроек используй на клиете ilogin. ... |
| 19.03.2004, 11:59 |
в логах сервера примерно тоже самое - 09:41:26 listener-thread: err = -956: oserr = 0: errstr = (sysadmin@devel): Client host or user (sysadmin@devel) is not trusted by the server. где-то все-таки надо приписать ip адрес клиента, только вот где ....... и похоже, что вопрос становится риторическим..... ... |
| 19.03.2004, 13:27 |
авторгде-то все-таки надо приписать ip адрес клиента, только вот где ....... и похоже, что вопрос становится риторическим..... Только в том случае, если ты хочешь коннектитится без пароля. Если ты коннектишся и авторизуешься парой логин-пароль, ip адрес нигде прописывать не нужно. Нужно настроить клиента чтобы он мозги не парил. ... |
| 19.03.2004, 13:34 |
Ты понял что hosts.equiv необходим что бы пользователь мог пройти без пароля? на win создай сам этот файлик в \system32\drivers\etc Как в этом файле должен быть прописан юзер, которому мой сервер должен доверять? Приведите пример. ... |
| 23.03.2006, 18:11 |
Привожу пример файла (надеюсь понятно, где там имя компа, а где логин юзера ?) #--------------------------------------------- # Not update this file without permission #--------------------------------------------- trainer vasilis trainer.aaaa.bbbb.ccc vasilis + vasilis trainer + ... |
| 29.03.2006, 12:37 |
start [/forum/topic.php?fid=44&fpage=51&tid=1608710]: |
37ms |
| others: | 230ms |
| total: | 325ms |
