архив нулевого уровня
Итак, провожу эксперименты с Informix 10.00.UC3 ONCONFIG # System Archive Tape Device TAPEDEV STDIO # Tape device path TAPEBLK 32 # Tape block size (Kbytes) TAPESIZE 10240 # Maximum amount of data to put on tape (Kbytes) # Log Archive Tape Device LTAPEDEV STDIO # Log tape device path LTAPEBLK 32 # Log tape block size (Kbytes) LTAPESIZE 10240 # Max amount of data to put on log tape (Kbytes) Делаю архив. ontape -s -L 0 >/opt/informix/back/lev0.arch 12:50:39 Maximum server connections 0 12:50:39 On-Line Mode 12:51:15 Booting Language <spl> from module <> 12:51:15 Loading Module <SPLNULL> 12:51:15 Level 0 Archive started on rootdbs, logdbs, workdbs 12:51:16 Archive on rootdbs, logdbs, workdbs Completed. 12:52:49 Checkpoint Completed: duration was 0 seconds. 12:52:49 Checkpoint loguniq 4, logpos 0x399018, timestamp: 0x11e1d 12:52:49 Maximum server connections 1 12:52:50 IBM Informix Dynamic Server Stopped. Восстанавливаю cat /opt/informix/back/lev0.arch | ontape -p 12:52:50 IBM Informix Dynamic Server Stopped. 12:53:28 IBM Informix Dynamic Server Started. Fri Jan 5 12:53:28 2007 12:53:28 Warning: ONCONFIG dump directory (DUMPDIR) '/tmp' has insecure permissions 12:53:28 Event alarms enabled. ALARMPROG = '/opt/informix/etc/alarmprogram.sh' 12:53:28 Booting Language <c> from module <> 12:53:28 Loading Module <CNULL> 12:53:28 Booting Language <builtin> from module <> 12:53:28 Loading Module <BUILTINNULL> 12:53:33 DR: DRAUTO is 0 (Off) 12:53:33 IBM Informix Dynamic Server Version 10.00.UC3R1TL Software Serial Number AAA#B000000 12:53:33 Your evaluation license will expire on 2007-06-20 00:00:00 12:53:33 IBM Informix Dynamic Server Initialized -- Shared Memory Initialized. 12:53:33 Data replication type and state information reset. To start DR, use the 'onmode -d' command and wait for the pair to be operational, before shutting down the database server 12:53:33 Dataskip is now OFF for all dbspaces 12:53:33 Restartable Restore has been ENABLED 12:53:33 Recovery Mode 12:53:38 Physical Restore of rootdbs, logdbs, workdbs started. 12:53:38 Checkpoint Completed: duration was 0 seconds. 12:53:38 Checkpoint loguniq 4, logpos 0x397018, timestamp: 0x11ddf 12:53:38 Maximum server connections 0 12:53:39 Checkpoint Completed: duration was 0 seconds. 12:53:39 Checkpoint loguniq 4, logpos 0x397018, timestamp: 0x11de5 12:53:39 Maximum server connections 0 12:53:39 Checkpoint Completed: duration was 0 seconds. 12:53:39 Checkpoint loguniq 4, logpos 0x397018, timestamp: 0x11deb 12:53:39 Maximum server connections 0 12:53:39 Physical Restore of rootdbs, logdbs, workdbs Completed. 12:53:39 Checkpoint Completed: duration was 0 seconds. 12:53:39 Checkpoint loguniq 4, logpos 0x397018, timestamp: 0x11def 12:53:39 Maximum server connections 0 После чего IBM Informix Dynamic Server Version 10.00.UC3R1TL -- Fast Recovery (CKPT REQ) -- Up 00:10:13 -- 141572 Kbytes Blocked:CKPT Userthreads address flags sessid user tty wait tout locks nreads nwrites 44c37018 ---P--D 1 root - 0 0 0 14 5 44c37544 ---P--F 0 root - 0 0 0 0 0 44c37a70 ---P--F 0 root - 0 0 0 0 0 44c37f9c ---P--F 0 root - 0 0 0 0 0 44c384c8 ---P--F 0 root - 0 0 0 0 0 44c389f4 ---P--- 5 root - 0 0 0 0 0 44c38f20 ---P--B 6 root - 0 0 0 0 0 44c3944c ---P--D 7 root - 0 0 0 0 0 44c39978 Y--P--D 8 root - 4407c130 0 0 0 0 9 active, 128 total, 11 maximum concurrent ... |
| 05.01.2007, 14:16 |
Логи проверь, если переполнены, сархивируй. ... |
| 05.01.2007, 14:23 |
Александр ФедоренкоЛоги проверь, если переполнены, сархивируй. Сервер только инициализирован, кроме системных баз нет ничего. ... |
| 05.01.2007, 15:34 |
Вообще то, не совсем понятно, что вы хотели сделать, ведь ontape -p выполняет только физическое восстановление и после него обязательно должно быть логическое восстановление. И обычно ontape -p применяется при восстановлении вторичного сервера в паре HDR, когда логи докатываются уже с первичного сервера. Т.е. в вашем случае сервер ждет наката логических журналов. Для вашего случая лучше использовать ontape -r для холодного восстановления всего сервера (сервер в оффлайне) или ontape -r -D для теплого восстановления отдельных ДБ-пространств (после этого также обязательно логическое восстановление). ... |
| 05.01.2007, 17:05 |
vasilisВообще то, не совсем понятно, что вы хотели сделать, ведь ontape -p выполняет только физическое восстановление и после него обязательно должно быть логическое восстановление. И обычно ontape -p применяется при восстановлении вторичного сервера в паре HDR. Огромная благодарность, после этих строчек я вспомнил, зачем все это затеял :) Получилось запустить десятку в паре. Продолжаем эксперименты с падением и поднятием одного из серверов. ... |
| 05.01.2007, 18:12 |
start [/forum/topic.php?fid=44&fpage=46&tid=1608484]: |
83ms |
35ms |
| others: | 248ms |
| total: | 419ms |
