Fix Central for Informix
Здесь можно найти Fix Pack for Informix (Fix, Fix for APAR Number and so on) http://www-912.ibm.com/eserver/support/fixes/fixcentral С уважением, Вадим. ... |
| 31.05.2007, 19:04 |
GVF112GVFЗдесь можно найти Fix Pack for Informix (Fix, Fix for APAR Number and so on) http://www-912.ibm.com/eserver/support/fixes/fixcentral Я позволю себе добавить, что Fix Central currently supports a limited set of products, and can only find prerequisites from that set. The currently supported products are: Informix Dynamic Server 10.00 and 9.40 WebSphere Portal Server 5.1 and 6.0 In the future, additional products will provide fixes (and any prerequisites they provide to other products) through Fix Central. А также пояснил бы, что такое Fix Pack: IBM Informix® Dynamic Server™ Fix Packs are full product files that can be downloaded with approved entitlement at the Passport Advantage (PPA) website. Informix Fix Packs were previously known as Interims. Надеюсь, я правильно понял, что Only customers with current PPA contracts can use the site ? Само собой, требуется регистрация You will need your IBM registration and login to use the link in the download table. ... |
| 31.05.2007, 21:02 |
Beginning June 1, 2007, entitled customers of the most popular Informix products will have a new way of finding and downloading fixes (fix packs, PIDs and patches (special builds)) via the Fix Central web site: http://www.ibm.com/eserver/support/fixes/ Supported products: * Informix Dynamic Server 9.40.XC9 (and later) * Informix Dynamic Server 10.00.XC6 (and later) * Client SDK 2.90.XC4R1 (and later) for UNIX platforms * Client SDK 2.90.TC6R1 (and later) for Windows platforms * end so on Who can use it Anyone with access to the Internet can access the Fix Central web site. However, Informix customers must maintain an active support subscription and have an IBM Web Identity account (available with a free, one-time registration) in order to download their entitled product(s). Fix Central help FAQs: http://www-304.ibm.com/jct01004c/systems/support/fixes/en/fixcentral/help/faq_sw.html ... |
| 31.05.2007, 23:02 |
Вадим, поясни, пожалуйста, мне, как не продавцу. customers with current PPA contracts и customers must maintain an active support subscription это одно и то же или разное ? И еще - Fix Pack по прежнему представляет собой полную версию продукта, которую надо переустанавливать, или это все же добавка, меньшая по размеру и которая обязательно требует старой версии ? ... |
| 01.06.2007, 12:09 |
Нам тут на днях дали скачать 10.00.UC6W3X1 под вывеской patch. Там был только oninit. А когда качали 10.00.UC6W3, это называлось pid, там был сервер полностью ... |
| 01.06.2007, 13:01 |
customers with current PPA contracts и customers must maintain an active support subscription это одно и то же или разное ? Одно не исключает другого. Насколько Я понял, current PPA contracts .. must maintain an active support subscription ... И еще - Fix Pack по прежнему представляет собой полную версию продукта, которую надо переустанавливать, или это все же добавка, меньшая по размеру и которая обязательно требует старой версии ? For Informix customers, L1 and L2 will begin to direct customers to Fix Central for fixes (fix packs, PIDs and patches) ... Насколько Я понял, есть возможность выкачать полную версию, получить заплатку для определенного APAR и т.д. С уважением, Вадим ... |
| 01.06.2007, 18:47 |
start [/forum/topic.php?fid=44&fpage=43&tid=1608382]: |
37ms |
38ms |
| others: | 240ms |
| total: | 348ms |
