Не подключаюсь к базе
informix 10 на suse На команду onstat - выдает shared memory: permision denied хотя в логе вот так: Кто подскажет как быть?? Tue Jul 7 14:03:47 2009 14:03:47 Warning: ONCONFIG dump directory (DUMPDIR) '/home/informix/tmp' has insecure permissions 14:03:47 Event alarms enabled. ALARMPROG = '/opt/IBM/informix/etc/no_log.sh' 14:03:47 Booting Language <c> from module <> 14:03:47 Loading Module <CNULL> 14:03:47 Booting Language <builtin> from module <> 14:03:47 Loading Module <BUILTINNULL> 14:03:52 DR: DRAUTO is 0 (Off) 14:03:52 IBM Informix Dynamic Server Version 10.00.FC5 Software Serial Number AAA#B000000 14:03:53 IBM Informix Dynamic Server Initialized -- Shared Memory Initialized. 14:03:53 Physical Recovery Started at Page (7:65478). 14:03:53 Physical Recovery Complete: 0 Pages Examined, 0 Pages Restored. 14:03:53 Logical Recovery Started. 14:03:53 10 recovery worker threads will be started. 14:03:56 Logical Recovery has reached the transaction cleanup phase. 14:03:56 Logical Recovery Complete. 0 Committed, 0 Rolled Back, 0 Open, 0 Bad Locks 14:03:57 Dataskip is now OFF for all dbspaces 14:03:57 Checkpoint Completed: duration was 0 seconds. 14:03:57 Checkpoint loguniq 6864, logpos 0x1214018, timestamp: 0x704de5c 14:03:57 Maximum server connections 0 14:03:57 On-Line Mode 14:08:36 IBM Informix Dynamic Server Started. 14:08:36 shmget: [EEXIST][17]: key 52564801: shared memory already exists 14:08:36 mt_shm_init: can't create resident segment ... |
| 07.07.2009, 15:18 |
zzzjaНа команду onstat - выдает shared memory: permision denied Под каким пользователем выполняли команду? Говорят же "по-русски" - "нет прав"! ... |
| 07.07.2009, 15:34 |
zzzja14:03:57 Maximum server connections 0 14:03:57 On-Line Mode 14:08:36 IBM Informix Dynamic Server Started. 14:08:36 shmget: [EEXIST][17]: key 52564801: shared memory already exists 14:08:36 mt_shm_init: can't create resident segment И не надо было пытаться его второй раз запустить :) Если onstat не работает, можно проверить Код: plaintext ... |
| 07.07.2009, 15:35 |
zzzja, Что показывает вывод ipcs ? > ipcs -a С уважением, Вадим. ... |
| 07.07.2009, 15:42 |
нашлась такая ошибка The chunk '/informix/tempdbs1' must have owner-ID "informix" and group-ID "root". The chunk '/informix/tempdbs2' must have owner-ID "informix" and group-ID "root". ... |
| 07.07.2009, 15:50 |
Устранил ошибки.. результата - нет. Что это может быть? ... |
| 07.07.2009, 16:54 |
Кроме прав на означенных файлах должен стоять suid-ный бит ... |
| 07.07.2009, 16:58 |
GVF112GVF, > ipcs -a ------ Shared Memory Segments -------- key shmid owner perms bytes nattch status 0x00000000 4882432 informix 600 262144 1 dest 0x00000000 2981949 informix 600 393216 2 dest ------ Semaphore Arrays -------- key semid owner perms nsems ------ Message Queues -------- key msqid owner perms used-bytes messages 0x000037a8 32769 root 666 0 0 ... |
| 07.07.2009, 17:11 |
zzzja, информикс работает и проблема только с onstat, или клиенты подключиться тоже не могут? Если с клиентами проблема (а до этого работало) - проще всего попробовать перезапустить сервер (весь комп, а не информикс). ... |
| 07.07.2009, 18:27 |
zzzja, Попробуй удалить сегменты informix: > ipcrm -m id потом, oninit -v ... :) С уважением, Вадим. ... |
| 07.07.2009, 19:56 |
start [/forum/topic.php?fid=44&fpage=28&tid=1607793]: |
40ms |
60ms |
| others: | 214ms |
| total: | 367ms |
