IDS 11.5 for Linux 5.1
С горем пополам поставил на линукс 11.5 сервер. Пытаюсь его проинициализировать - выдает ошибку: oninit -iv: авторThis action will initialize IBM Informix Dynamic Server; any existing IBM Informix Dynamic Server databases will NOT be accessible - Do you wish to continue (y/n)? Checking group membership to determine server run mode...succeeded Reading configuration file '/usr/informix/etc/onconfig.std'...succeeded Creating /INFORMIXTMP/.infxdirs...succeeded Creating infos file "/usr/informix/etc/.infos.lx51ids115"...succeeded Linking conf file "/usr/informix/etc/.conf.lx51ids115"...succeeded Checking config parameters...succeeded Writing to infos file...succeeded Allocating and attaching to shared memory...succeeded Creating resident pool 10570 kbytes...succeeded Allocating 100016 kbytes for buffer pool of 2K page size...succeeded Initializing rhead structure...succeeded Initialization of Encryption...succeeded Initializing ASF...succeeded Initializing Dictionary Cache and SPL Routine Cache...succeeded Bringing up ADM VP...succeeded Creating VP classes...succeeded Onlining 0 additional cpu vps...succeeded Onlining 2 IO vps...succeeded Forking main_loop thread...succeeded Initializing DR structures...succeeded Forking 1 'soctcp' listener threads...succeeded Starting tracing...succeeded Initializing 8 flushers...succeeded oninit: atal error in shared memory initialization Что надо сделать? ... |
| 17.12.2009, 12:50 |
почитать файл $INFORMIXDIR/release/*/*/ids_machine_notes_ХХХХ.txt на предмет тюннинга параметров ядра ... |
| 17.12.2009, 13:07 |
Я правильно понимаю что речь вот про это: авторSystem Configuration ==================== 1. Kernel Parameters The values of the kernel parameters that were used for testing this product are given below. These values might need to be tuned depending on the application and availability of system resources. They can either be dynamically changed in the /proc file system or are defined in the kernel sources and can be changed by rebuilding the kernel. SHMMAX: 33554432 SHMMIN: 1 SHMMNI: 128 SHMSEG: 128 SHMALL: 4194304 SEMMNI: 128 SEMMSL: 250 SEMMNS: 32000 SEMOPM: 32 - The value of the kernel parameter "SEMMSL" should be set to at least 100. This is the maximum number of semaphores per set. 2. Location of Shared Memory The ONCONFIG variable SHMBASE is set to the following: SHMBASE 0x44000000L - SHMBASE can also be set to start above the shared library addresses. When doing so, ensure that dynamically loaded shared libraries do not collide with the shared memory segments. The address space layout can be checked by the following command: $ cat /proc/<pid of oninit process>/maps - Some Linux distributions (e.g. SUSE SLES 10) provide a way to dynamically change the default start address for shared libraries on a per-process basis. This feature is available if the file /proc/$$/mapped_base exists. To change the start address for shared libraries of the oninit processes, the new start address needs to be specified by the user root in the shell from where oninit is started. For example, the following sets the start address of shared libraries to 0xB0000000L: $ echo $$ 29712 $ su root Password: # echo 0xB0000000 > /proc/29712/mapped_base # exit $ oninit 3. JRE Shared Libraries In order to ensure the JRE shared libraries are loaded properly, the following steps are necessary: a. Add the following lines at the end of /etc/ld.so.conf <$INFORMIXDIR>/extend/krakatoa/jre/bin <$INFORMIXDIR>/extend/krakatoa/jre/bin/classic <$INFORMIXDIR>/extend/krakatoa/jre/lib This assumes the bundled JRE in $INFORMIXDIR/extend/krakatoa/jre is used. Substitute <$INFORMIXDIR> by the value of your INFORMIXDIR environment variable. c. Run ldconfig as root # ldconfig ... |
| 17.12.2009, 13:12 |
Да, именно про это. ... |
| 17.12.2009, 13:52 |
В общем делаю следующее Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. Т.е. выставляю переменные окружения и те переменные что указанаы в мануале выше. Получаю все то же сообщение об ошибке при инициализации. ... |
| 17.12.2009, 14:36 |
Петров Андрей Что надо сделать? М.б. посмотреть, что в файле $INFORMIXDIR/online.log? ... |
| 17.12.2009, 14:38 |
А его там нема. Онконфиг тоже не могу найти. ... |
| 17.12.2009, 14:46 |
Петров Андрей Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. Это не переменные окружения. В Red Hat есть файл Код: plaintext Вот туда их и надо определить. ... |
| 17.12.2009, 14:48 |
Есть online.log d informix/tmp но в нем нет ошибок инициализации сервера... Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. ... |
| 17.12.2009, 14:49 |
Петров АндрейА его там нема. Онконфиг тоже не могу найти. Вы же используете: Код: plaintext А в нем указан online.log ... |
| 17.12.2009, 14:49 |
Петров АндрейЕсть online.log d informix/tmp но в нем нет ошибок инициализации сервера... Код: plaintext 1. 2. 3. А это что? Чанка нет? ... |
| 17.12.2009, 14:51 |
И еще до кучи: Код: plaintext Shared Memory нужно очищать после такого. ... |
| 17.12.2009, 15:07 |
Все заработало - спасибо. ... |
| 17.12.2009, 15:42 |
Петров АндрейВ общем делаю следующее export SHMMAX=33554432 export SHMMIN=1 export SHMMNI=128 export SHMSEG=128 export SHMALL=4194304 export SEMMNI=128 export SEMMSL=250 export SEMMNS=32000 export SEMOPM=32 export SHMBASE=0x44000000L Т.е. выставляю переменные окружения и те переменные что указанаы в мануале выше. Получаю все то же сообщение об ошибке при инициализации. Андрей, вы не сисадмин и не DBA ? И вас силой заставили перейти на Линукс ? И у вас нет ни одной книжки по Линуксу и обрезали Инет ? Извините, я в шоке (может и зря, но все равно грустно) ... |
| 17.12.2009, 16:27 |
Я не админ и не DBA - так что представьте себе как грустно мне. Интернет есть но нет времени к сожалению. Зато есть еще вопрос: Я накатил на сервер базу а архивироваться она не хочет... в onconfig имеем: авторTAPEDEV nul TAPEBLK 32 TAPESIZE 0 LTAPEDEV nul LTAPEBLK 32 LTAPESIZE 0 При выполнении команды ontape -s получаю вот такое сообщение: ... |
| 17.12.2009, 17:50 |
Андрей, Если архив вам реально не нужен, а работаете вы в ОС Linux, то использовать надо не nul (это для Windows), а /dev/null ... |
| 17.12.2009, 20:56 |
Скачайте книгу по установке и первоначальной настройке информикса и большинство вопросов , которые Вы сей час задаете исчезнут. |Informix 11.5 ... |
| 18.12.2009, 14:49 |
Продолжаем разговор. С UC1 вроде все бвло нормалек - теперь приходится все заново с UC5. При старте сервер выдает следующий лог и падает: автор18:33:17 IBM Informix Dynamic Server Started. Fri Dec 18 18:33:19 2009 18:33:19 Event alarms enabled. ALARMPROG = '/usr/informix/etc/alarmprogram.sh' 18:33:19 Booting Language <c> from module <> 18:33:19 Loading Module <CNULL> 18:33:19 Booting Language <builtin> from module <> 18:33:19 Loading Module <BUILTINNULL> 18:33:24 DR: DRAUTO is 0 (Off) 18:33:24 DR: ENCRYPT_HDR is 0 (HDR encryption Disabled) 18:33:24 Event notification facility epoll enabled. 18:33:24 IBM Informix Dynamic Server Version 11.50.UC5 Software Serial Number AAA#B000000 18:33:47 IBM Informix Dynamic Server Initialized -- Complete Disk Initialized. 18:33:47 Started 1 B-tree scanners. 18:33:47 B-tree scanner threshold set at 5000. 18:33:47 B-tree scanner range scan size set to -1. 18:33:47 B-tree scanner ALICE mode set to 6. 18:33:47 B-tree scanner index compression level set to med. 18:33:47 Dataskip is now OFF for all dbspaces 18:33:48 Checkpoint Completed: duration was 0 seconds. 18:33:48 Fri Dec 18 - loguniq 1, logpos 0x33c, timestamp: 0xb8 Interval: 2 18:33:48 Maximum server connections 0 18:33:48 Checkpoint Statistics - Avg. Txn Block Time 0.000, # Txns blocked 0, Plog used 6, Llog used 1 18:33:48 On-Line Mode 18:33:48 Building 'sysmaster' database ... 18:33:57 Booting Language <spl> from module <> 18:33:57 Loading Module <SPLNULL> 18:33:59 Unloading Module <SPLNULL> 18:34:00 Checkpoint Completed: duration was 0 seconds. 18:34:00 Fri Dec 18 - loguniq 1, logpos 0xebe018, timestamp: 0xf988 Interval: 3 18:34:00 Maximum server connections 1 18:34:00 Checkpoint Statistics - Avg. Txn Block Time 0.000, # Txns blocked 0, Plog used 7, Llog used 3774 18:34:03 Loading Module <SPLNULL> 18:34:04 Unloading Module <SPLNULL> 18:34:06 Checkpoint Completed: duration was 0 seconds. 18:34:06 Fri Dec 18 - loguniq 1, logpos 0x1352018, timestamp: 0x14aab Interval: 4 18:34:06 Maximum server connections 1 18:34:06 Checkpoint Statistics - Avg. Txn Block Time 0.000, # Txns blocked 0, Plog used 102, Llog used 1172 18:34:07 Loading Module <SPLNULL> 18:34:08 Logical Log 1 Complete, timestamp: 0x16535. 18:34:08 Unloading Module <SPLNULL> 18:34:10 Checkpoint Completed: duration was 0 seconds. 18:34:10 Fri Dec 18 - loguniq 2, logpos 0x430018, timestamp: 0x1984a Interval: 5 18:34:10 Maximum server connections 1 18:34:10 Checkpoint Statistics - Avg. Txn Block Time 0.000, # Txns blocked 0, Plog used 71, Llog used 1126 18:34:10 'sysmaster' database built successfully. 18:34:11 'sysutils' database built successfully. 18:34:11 'sysuser' database built successfully. 18:34:17 Building 'sysadmin' database ... 18:34:19 Loading Module <SPLNULL> 18:34:20 'sysadmin' database built successfully. 18:34:20 SCHAPI: Started dbScheduler thread. 18:34:21 SCHAPI: Started 2 dbWorker threads. 18:34:21 Checkpoint Completed: duration was 1 seconds. 18:34:21 Fri Dec 18 - loguniq 2, logpos 0xc26018, timestamp: 0x21a17 Interval: 6 18:34:21 Maximum server connections 1 18:34:21 Checkpoint Statistics - Avg. Txn Block Time 0.000, # Txns blocked 1, Plog used 93, Llog used 2169 Далее при старте (oninit -v) выдает (online.log): 18:35:17 IBM Informix Dynamic Server Started. 18:35:17 shmget: [EEXIST][17]: key 52564801: shared memory already exists 18:35:17 mt_shm_init: can't create resident segment 18:36:32 IBM Informix Dynamic Server Started. 18:36:32 shmget: [EEXIST][17]: key 52564801: shared memory already exists 18:36:32 mt_shm_init: can't create resident segment После перезапуска вирт. машины все команды oninit проходят но опять падает как в первом логе... ... |
| 21.12.2009, 14:47 |
Я что то не вижу что бы он по первому логу падал , судя по всему Вы запустили его с oninit -i , а дальше вы пробуете похоже запустить его повторно. Покажите вывод ps -ef | grep oninit когда вы пытаетесь сделать oninit -v и сервер вам отвечает ошибкой. ... |
| 21.12.2009, 14:55 |
или вы запускаете oninit -i ,а потом сразу после отработки первой oninit -v ? ... |
| 21.12.2009, 14:58 |
Да сначала oninit -iv Потом после того как оно отработало oninit -v ... |
| 21.12.2009, 15:00 |
Вопрос снят :-) ... |
| 21.12.2009, 15:03 |
start [/forum/topic.php?fid=44&fpage=25&tid=1607670]: |
39ms |
61ms |
| others: | 208ms |
| total: | 347ms |
