update ... (select)
помогите пожалуйста где ошибка ? db2 "UPDATE BUF_COL_PRODUCT as B SET PRODUCT_ID = (SELECT N.PRODUCT_ID FROM COL_PRODUCT as N WHERE N.CODE=B.CODE)" DB21034E The command was processed as an SQL statement because it was not a valid Command Line Processor command. During SQL processing it returned: SQL0407N Assignment of a NULL value to a NOT NULL column "TBSPACEID=2, TABLEID=39, COLNO=0" is not allowed. SQLSTATE=23502 db2 "SELECT COLNAME ,COLNO, NULLS FROM SYSCAT.COLUMNS WHERE TABSCHEMA='WEBUSER' AND TABNAME='COL_PRODUCT' ORDER BY COLNO" COLNAME COLNO NULLS ---------------- ------- ----- PRODUCT_ID 0 N CODE 1 N db2 "SELECT COLNAME ,COLNO, NULLS FROM SYSCAT.COLUMNS WHERE TABSCHEMA='WEBUSER' AND TABNAME='BUF_COL_PRODUCT' ORDER BY COLNO" COLNAME COLNO NULLS ---------------- ------- ----- PRODUCT_ID 0 N CODE 1 N ... |
| 17.04.2003, 15:58:31 |
update ... (select)
а нет ошибки SELECT N.PRODUCT_ID FROM COL_PRODUCT as N WHERE N.CODE=B.CODE вернул стольник ... |
| 17.04.2003, 16:25:01 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1606616]: |
184ms |
27ms |
| others: | 202ms |
| total: | 445ms |
