Ваше мнение по поводу ошибки
Подскажите, где взять описание ошибок по их кодам. собственно ошибка такая: Ошибка соединения CLI. SQL30081N Ошибка связи. Использовался протокол связи: "TCP/IP". API связи: "SOCKETS". Ошибка обнаружена в положении: "". Ошибку обнаружила функция связи: "connect". Коды ошибок протокола: "10061", "*", "*".; SQLSTATE=08001 заранее спасибо ... |
| 02.07.2003, 16:25:19 |
-------------------------------- Script -------------------------------- ? SQL30081N ; ------------------------------------------------------------------------ SQL30081N A communication error has been detected. Communication protocol being used: <protocol>. Communication API being used: <interface>. Location where the error was detected: <location>. Communication function detecting the error: <function>. Protocol specific error code(s): <rc1>, <rc2>, <rc3>. Explanation: An error has been detected by the communication subsystem. If the connection has already been established, possible causes include the following: o A communication subsystem error at the client node or server node has caused the connection to go down. o A communication subsystem error at the SOCKS server, if one is being used, has caused the connection to go down. o A network error has caused the connection to go down. o The database agent at the server was forced off by the system administrator. o The database agent at the server was terminated due to an abnormal termination of a key database manager process. If you are trying to establish a new connection, possible causes include the following: o The remote database server has not been cataloged correctly at the client. o The database manager configuration file at the server has not been configured with the proper communication parameters. o The communication subsystem at the client node or server node has not been configured correctly, or has not been started successfully. o The communication subsystem at the SOCKS server, if one is being used, has not been configured correctly, or has not been started successfully. o The DB2COMM environment variable at the server doesn't specify the communication protocol used by the client. o The database manager at the server has not been started, or has not been started successfully. One or more of the communication protocols specified by DB2COMM may not have been successfully started. Refer to the token values for details. Depending on the protocol being used and the communication function invoked, some tokens may not be applicable. The following is the explanation of the token values: <protocol> The actual communication protocol being used. Valid token values are: o TCP/IP o APPC o NETBIOS o IPX/SPX <interface> The application programming interface used to invoke the above communication protocol services. Valid token values are: o SOCKETS o SOCKS o CPI-C o DLR or DD o TLI or Connection/Bindery <location> This is a protocol specific ID which uniquely identifies the node that detected the error. If the protocol being used is: o TCP/IP The format of the ID is the Internet address in dot notation. o APPC The format of the ID is the fully qualified LU name (networkID.LUname). o NETBIOS The format of the ID is the Workstation name (nname). o IPX/SPX The format of the ID is the network address and node address in hexadecimal notation (network.node). If the location information is not available at the time that the error occurred, this token is not filled in. <function> The name of the communication subsystem function that returned the error code(s). <rc1>, <rc2>, <rc3> The list of the available error codes and subcodes that are specific to each protocol being used. Tokens that are not applicable contain "*". If the protocol being used is: o TCP/IP - If present, <rc1> contains the global errno value from the TCP/IP sockets function call. When using Windows Sockets, if present, <rc1> contains the error from the TCP/IP sockets function call returned by WSAGetLastError(). - If present, <rc2> contains the global h_errno value from the TCP/IP name resolution function call. When using Windows Sockets, if present, <rc2> contains the error from the TCP/IP database function call returned by WSAGetLastError(). - If <rc3> is present and contains "0", it means that the TCP/IP connection has been closed. This could be caused by one of the following: - The database agent at the server was forced off by the system administrator. - A database agent could not be started at the server because the maxagents database manager configuration parameter has been exceeded. Check the First Failure Service Log (DB2DIAG.LOG) at the server to see if an error message has been logged. - The connection may have been closed by the remote server at the TCP/IP level. - The database agent at the server was terminated due to an abnormal termination of a key database manager process. Note: When using Windows Sockets, if the <function> is WSAStartup, and <rc1> is 0, then <rc2> contains the Windows Sockets Specification version level requested by DB2, and <rc3> contains the Windows Sockets Specification version level supported by the Windows Sockets DLL. o APPC <rc1> contains the return code from the CPI-C function. If present, <rc2> contains the global errno value from the CPI-C function call. <rc3> is not applicable. o NETBIOS <rc1> contains the return code from the call to NetBIOS. <rc2> and <rc3> are not applicable. o IPX/SPX <rc1> contains the global t_errno value from the call to TLI Services, or the return code from the call to NetWare Connection or Bindery Services. If the <rc1> t_errno is TLOOK, <rc2> contains the TLI event that has occurred. If the <rc2> event is T_DISCONNECT, <rc3> contains the disconnect reason code. On AIX, if the <rc1> t_errno is TSYSERR, <rc3> contains the system errno (defined in sys/errno.h). If <rc1> contains the error return code from a call to AIX NetWare Connection or Bindery Services, <rc2> contains the error generator. See the Communications Errors appendix of the Message Reference for more information on specific communication error codes. User Response: If the connection has already been established, check if: 1. The database agent at the server has been forced off. 2. The database manager at the server has abnormally terminated. 3. A communication subsystem or network error has occurred. See the Message Reference for more information on specific communication error codes. If you are trying to establish a new connection, check if: 1. The remote database server is cataloged properly on the client node. 2. The database manager configuration file at the server is configured with the proper communication related parameters. If the database manager configuration parameters have been updated at the server, ensure that you stop and then re-start the database manager, for the changes to take effect. 3. The communication subsystems on both client and server nodes are configured and started up properly. 4. The DB2COMM environment variable at the server specifies the communication protocol used by the client. 5. The database manager at the server is successfully started. Start database manager processing at the server should have returned SQL1063, and not SQL5043. If SQL5043 is returned, check the First Failure Service Log (DB2DIAG.LOG) for more information. 6. A communication subsystem or network error has occurred. If the problem persists, consult with your network administrator and/or communication expert to determine the cause of the problem using the set of tokens provided. sqlcode: -30081 sqlstate: 08001 ... |
| 02.07.2003, 16:26:59 |
WSAECONNREFUSED (10061): The connection has been refused. If you are trying to connect to the database, check that the database manager and TCP/IP protocol support at the server has been started successfully. порт не тот указал? ... |
| 02.07.2003, 16:32:31 |
Спасибо, NewYear, очень подробно и доступно. Может посоветуешь, где такую документацию ещё взять, и побольше, побольше :) Может ссылок подкинешь... ... |
| 03.07.2003, 12:45:56 |
а!!! понял где взять!!! здесь: db2cmdn.exe ? SQL30081N Но ссылок всё равно подкинь если есть, спасибо. ... |
| 03.07.2003, 12:51:14 |
start [/forum/search_topic.php?author=Sergmaestro&author_mode=last_topics&do_search=1]: |
194ms |
41ms |
| others: | 1740ms |
| total: | 2042ms |
