при конекте к БД oшибка
привет всем! при конекте к БД вылетает такая ошибка: SQL1084C Shared memory segments cannot be allocated. SQLSTATE=57019 параметры БД такие Database Manager Configuration Node type = Database Server with local and remote clients Database manager configuration release level = 0x0a00 CPU speed (millisec/instruction) (CPUSPEED) = 4,251098e-07 Max number of concurrently active databases (NUMDB) = 8 Data Links support (DATALINKS) = NO Federated Database System Support (FEDERATED) = NO Transaction processor monitor name (TP_MON_NAME) = Default charge-back account (DFT_ACCOUNT_STR) = Java Development Kit installation path (JDK_PATH) = /opt/IBMJava2-131 Diagnostic error capture level (DIAGLEVEL) = 3 Notify Level (NOTIFYLEVEL) = 3 Diagnostic data directory path (DIAGPATH) = Default database monitor switches Buffer pool (DFT_MON_BUFPOOL) = OFF Lock (DFT_MON_LOCK) = OFF Sort (DFT_MON_SORT) = OFF Statement (DFT_MON_STMT) = OFF Table (DFT_MON_TABLE) = OFF Timestamp (DFT_MON_TIMESTAMP) = ON Unit of work (DFT_MON_UOW) = OFF Monitor health of instance and databases (HEALTH_MON) = OFF SYSADM group name (SYSADM_GROUP) = SYSCTRL group name (SYSCTRL_GROUP) = SYSMAINT group name (SYSMAINT_GROUP) = SYSMON group name (SYSMON_GROUP) = Database manager authentication (AUTHENTICATION) = SERVER Cataloging allowed without authority (CATALOG_NOAUTH) = NO Trust all clients (TRUST_ALLCLNTS) = YES Trusted client authentication (TRUST_CLNTAUTH) = CLIENT Bypass federated authentication (FED_NOAUTH) = NO Default database path (DFTDBPATH) = /home/db2inst1 Database monitor heap size (4KB) (MON_HEAP_SZ) = 90 Java Virtual Machine heap size (4KB) (JAVA_HEAP_SZ) = 512 Audit buffer size (4KB) (AUDIT_BUF_SZ) = 0 Size of instance shared memory (4KB) (INSTANCE_MEMORY) = AUTOMATIC Backup buffer default size (4KB) (BACKBUFSZ) = 1024 Restore buffer default size (4KB) (RESTBUFSZ) = 1024 Sort heap threshold (4KB) (SHEAPTHRES) = 20000 Directory cache support (DIR_CACHE) = YES Application support layer heap size (4KB) (ASLHEAPSZ) = 15 Max requester I/O block size (bytes) (RQRIOBLK) = 32767 Query heap size (4KB) (QUERY_HEAP_SZ) = 1000 DRDA services heap size (4KB) (DRDA_HEAP_SZ) = 128 Workload impact by throttled utilities(UTIL_IMPACT_LIM) = 100 Priority of agents (AGENTPRI) = SYSTEM Max number of existing agents (MAXAGENTS) = 200 Agent pool size (NUM_POOLAGENTS) = 100(calculated) Initial number of agents in pool (NUM_INITAGENTS) = 0 Max number of coordinating agents (MAX_COORDAGENTS) = MAXAGENTS Max no. of concurrent coordinating agents (MAXCAGENTS) = MAX_COORDAGENTS Max number of client connections (MAX_CONNECTIONS) = MAX_COORDAGENTS Keep fenced process (KEEPFENCED) = YES Number of pooled fenced processes (FENCED_POOL) = MAX_COORDAGENTS Initial number of fenced processes (NUM_INITFENCED) = 0 Index re-creation time (INDEXREC) = RESTART Transaction manager database name (TM_DATABASE) = 1ST_CONN Transaction resync interval (sec) (RESYNC_INTERVAL) = 180 SPM name (SPM_NAME) = SPM log size (SPM_LOG_FILE_SZ) = 256 SPM resync agent limit (SPM_MAX_RESYNC) = 20 SPM log path (SPM_LOG_PATH) = TCP/IP Service name (SVCENAME) = Discovery mode (DISCOVER) = SEARCH Discover server instance (DISCOVER_INST) = ENABLE Maximum query degree of parallelism (MAX_QUERYDEGREE) = ANY Enable intra-partition parallelism (INTRA_PARALLEL) = NO No. of int. communication buffers(4KB)(FCM_NUM_BUFFERS) = 1024 ######################################################## Database Configuration for Database TESTDB Database configuration release level = 0x0a00 Database release level = 0x0a00 Database territory = DE Database code page = 1208 Database code set = UTF-8 Database country/region code = 49 Dynamic SQL Query management (DYN_QUERY_MGMT) = DISABLE Discovery support for this database (DISCOVER_DB) = ENABLE Default query optimization class (DFT_QUERYOPT) = 5 Degree of parallelism (DFT_DEGREE) = 1 Continue upon arithmetic exceptions (DFT_SQLMATHWARN) = NO Default refresh age (DFT_REFRESH_AGE) = 0 Number of frequent values retained (NUM_FREQVALUES) = 10 Number of quantiles retained (NUM_QUANTILES) = 20 Backup pending = NO Database is consistent = YES Rollforward pending = NO Restore pending = NO Multi-page file allocation enabled = NO Log retain for recovery status = NO User exit for logging status = NO Data Links Token Expiry Interval (sec) (DL_EXPINT) = 60 Data Links Write Token Init Expiry Intvl(DL_WT_IEXPINT) = 60 Data Links Number of Copies (DL_NUM_COPIES) = 1 Data Links Time after Drop (days) (DL_TIME_DROP) = 1 Data Links Token in Uppercase (DL_UPPER) = NO Data Links Token Algorithm (DL_TOKEN) = MAC0 Database heap (4KB) (DBHEAP) = 1200 Size of database shared memory (4KB) (DATABASE_MEMORY) = AUTOMATIC Catalog cache size (4KB) (CATALOGCACHE_SZ) = (MAXAPPLS*4) Log buffer size (4KB) (LOGBUFSZ) = 8 Utilities heap size (4KB) (UTIL_HEAP_SZ) = 5000 Buffer pool size (pages) (BUFFPAGE) = 1000 Extended storage segments size (4KB) (ESTORE_SEG_SZ) = 16000 Number of extended storage segments (NUM_ESTORE_SEGS) = 0 Max storage for lock list (4KB) (LOCKLIST) = 100 Max size of appl. group mem set (4KB) (APPGROUP_MEM_SZ) = 30000 Percent of mem for appl. group heap (GROUPHEAP_RATIO) = 70 Max appl. control heap size (4KB) (APP_CTL_HEAP_SZ) = 128 Sort heap thres for shared sorts (4KB) (SHEAPTHRES_SHR) = (SHEAPTHRES) Sort list heap (4KB) (SORTHEAP) = 256 SQL statement heap (4KB) (STMTHEAP) = 2048 Default application heap (4KB) (APPLHEAPSZ) = 256 Package cache size (4KB) (PCKCACHESZ) = (MAXAPPLS*8) Statistics heap size (4KB) (STAT_HEAP_SZ) = 4384 Interval for checking deadlock (ms) (DLCHKTIME) = 10000 Percent. of lock lists per application (MAXLOCKS) = 10 Lock timeout (sec) (LOCKTIMEOUT) = -1 Changed pages threshold (CHNGPGS_THRESH) = 60 Number of asynchronous page cleaners (NUM_IOCLEANERS) = 1 Number of I/O servers (NUM_IOSERVERS) = 3 Index sort flag (INDEXSORT) = YES Sequential detect flag (SEQDETECT) = YES Default prefetch size (pages) (DFT_PREFETCH_SZ) = 32 Track modified pages (TRACKMOD) = OFF Default number of containers = 1 Default tablespace extentsize (pages) (DFT_EXTENT_SZ) = 32 Max number of active applications (MAXAPPLS) = AUTOMATIC Average number of active applications (AVG_APPLS) = 1 Max DB files open per application (MAXFILOP) = 64 Log file size (4KB) (LOGFILSIZ) = 1000 Number of primary log files (LOGPRIMARY) = 3 Number of secondary log files (LOGSECOND) = 2 Changed path to log files (NEWLOGPATH) = Path to log files = /databases/db2inst1/NODE0000/SQL00008/SQLOGDIR/ Overflow log path (OVERFLOWLOGPATH) = Mirror log path (MIRRORLOGPATH) = First active log file = Block log on disk full (BLK_LOG_DSK_FUL) = NO Percent of max active log space by transaction(MAX_LOG) = 0 Num. of active log files for 1 active UOW(NUM_LOG_SPAN) = 0 Group commit count (MINCOMMIT) = 1 Percent log file reclaimed before soft chckpt (SOFTMAX) = 100 Log retain for recovery enabled (LOGRETAIN) = OFF User exit for logging enabled (USEREXIT) = OFF Auto restart enabled (AUTORESTART) = ON Index re-creation time (INDEXREC) = SYSTEM (RESTART) Default number of loadrec sessions (DFT_LOADREC_SES) = 1 Number of database backups to retain (NUM_DB_BACKUPS) = 12 Recovery history retention (days) (REC_HIS_RETENTN) = 366 TSM management class (TSM_MGMTCLASS) = TSM node name (TSM_NODENAME) = TSM owner (TSM_OWNER) = TSM password (TSM_PASSWORD) = ... |
| 28.05.2004, 12:14:03 |
it means the the amount of RAM is smaller than DB2 is trying to allocate. Check bufferpools size. use CC and wizards to configure a database if you can't do it manualy. ... |
| 28.05.2004, 13:27:21 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1606265]: |
69ms |
47ms |
| others: | 223ms |
| total: | 398ms |
