чЕГО ЭТО ТАКОЕ?
Грамотные люди, подскажите плиз!?!?!? Видел пиратские диски ... Называецца : "WebSphere Extended Transactional Client v5.3" аж на целых 3 дисках продается:) Это что за продукт такой? Новый? И чего можно с него поиметь??? ... |
| 23.07.2004, 19:29:44 |
чЕГО ЭТО ТАКОЕ?
A WebSphere MQ extended transactional client is a WebSphere MQ client with some additional function. This function enables a client application, within the same unit of work: * To put messages to, and get messages from, queues that are owned by the queue manager to which it is connected * To update the resources of a resource manager other than a WebSphere MQ queue manager More information www-3.ibm.com/software/integration/wmq Custom disc installation instructions 1. Log on as root. 2. Mount the disc device using the appropriate mount point (e.g., /mnt/disc). 3. Create a temporary directory and change to that directory. 4. Type unzip /mnt/disc/mqt5302s/mqt5302s.zip and press Enter to uncompress the file. 5. Before beginning the installation, refer to csqzar00.pdf. 6. Run TXClient/mqlicense.sh to view MQ Extended Transactional Client license agreement. 7. Run pkgadd -d TXClient/mqs530.img to install MQ Extended Transactional Client. ... |
| 26.07.2004, 11:13:54 |
чЕГО ЭТО ТАКОЕ?
за деньги? или если есть уже сервер, то этот advanced клиент бесплатный? ... |
| 26.07.2004, 12:05:22 |
чЕГО ЭТО ТАКОЕ?
http://www.developer.ibm.com/tech/faq/individual?oid=2:81709 ... |
| 26.07.2004, 13:22:49 |
чЕГО ЭТО ТАКОЕ?
спасибо. зато он зачем-то на пиратских дисках :) ... |
| 26.07.2004, 13:40:34 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1606183]: |
179ms |
34ms |
| others: | 186ms |
| total: | 432ms |
