db2 8.2.0 + MQSeries 5.2 CSD08 w2k -- нужен fix?
вопрос, конечно, к Николаю Куликову. :) вряд ли кто кроме IBM здесь что-то скажет. db2 8.2.0 + MQSeries 5.2 CSD08 связка MQSeries координатор транзакций + db2 resource manager не работает. со стороны MQ: 15.11.2004 17:18:47 AMQ7604: The XA resource manager 'XXXXXXX' was not available when called for xa_open. The queue manager is continuing without this resource manager. EXPLANATION: The XA resource manager 'XXXXXXX' has indicated that it is not available, by returning XAER_RMERR on an xa_open request or XAER_RMFAIL when called for something else. Normally this indicates that the resource manager has been shut down. In this case the resource manager cannot participate in any new transactions. Any in-flight transactions in which it was involved will be backed out, and any transactions in which it is in-doubt will only be resolved when contact with the resource manager is re-established. A further message will be issued when the queue manager has been able to do this. If the problem occurred on an xa_open request, and the resource manager should be available, then there may be a configuration problem. ACTION: Try to establish the reason why the resource manager is unavailable. It may be that an invalid XAOpenString has been defined for the resource manager in the 'qm.ini' configuration file. If this is the case, stop and then restart the queue manager so that any change will be picked up. Alternatively, the queue manager may be reaching a resource constraint with this resource manager. For example, the resource manager may not be able to accommodate all of the queue manager processes being connected at one time, you may need to alter one of its tuning parameters. со стороны db2 -- ничего не пишет. все нормально сконфигурировано. настраивал я до этого 1000 раз с другими версиями db2 и MQ, все работало. db2 доступна, connect c теми же параметрами, что XAOpenString выполняется. паратетр TP_MON_NAME корректный. switch тоже нормальный, в процессе поиска бага я его пересобрал с библиотеками db2 c данной машины. да и если он ненормальный, менеджер не загружается. я думаю что это баг, причем в db2. шанс что я ошибся, очень маленький. можно посмотреть, не было ли у кого-нибудь такого, и что можно сделать? возвратиться в db2 8.1.x довольно трудоемко, да и заказчик может не захотеть. ... |
| 21.12.2004, 10:57:16 |
отвечу вечером сейчас нет доступа к PMR&APAR ... |
| 21.12.2004, 11:53:18 |
ну и что? могу я расчитывать на ответ? ... |
| 24.12.2004, 16:24:18 |
Я посмотрел, вроде ничего похожего в PMR ах нет. Давай сделаем новый PMR. пиши мне письмо... ... |
| 30.12.2004, 19:18:49 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1606045]: |
288ms |
46ms |
| others: | 258ms |
| total: | 644ms |
