Какая есть среда для создания sql-запросов и хп для db2
Я работаю программистом. В db2 новичок. Какая есть удобная среда для создания sql-запросов и хп для db2? Спасибо! ... |
| 29.01.2005, 00:43 |
you favorite editor, so far you are a programmer. SQL Builderis a part of DB2. Read tutorials/doc, it is described there. Also exist third-party software, but it cost. ... |
| 29.01.2005, 08:55 |
Which? For example... ggvyou favorite editor, so far you are a programmer. SQL Builderis a part of DB2. Read tutorials/doc, it is described there. Also exist third-party software, but it cost. ... |
| 29.01.2005, 15:22 |
AlvasWhich? For example...Привет! Смотрите здесь... Также сюда можно добавить Aqua Data Studio Желаю удачи! С уважением, kdima71. ... |
| 29.01.2005, 15:35 |
I can't add somthing to what kdima said. As for me, I'm happy with vim. Each sql statement I put in a file, and after years I got a huge library. It is not useful only, it is memory also :) I do not mean select * from table I've been tought to type each query in a file, it gives additional time to think befor run. ... |
| 29.01.2005, 21:33 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1606021]: |
51ms |
| others: | 265ms |
| total: | 386ms |
