powered by simpleCommunicator - 2.0.60     © 2026 Programmizd 02
Форумы / IBM DB2, WebSphere, IMS, U2 [игнор отключен] [закрыт для гостей] / Update MS SQL 2000 on change in IBM Universe
3 сообщений из 3, страница 1 из 1
    #33719186
IgorTaDaDaDa
I have never heard about IBM Universe before I had to integrate my application with IBM Universe (this time).
When I deal with two MS SQL servers I replicate data I need from other vendor DB to my application DB and write triggers on replicated tables which update my application.
If you know Universe's possibilities please offer some options.
I believe there is a better way rather than creating a CSV file on change in Universe and scheduled DTS package to process files and suck it in SQL 2000.
Thks a lot,
Igor
    #33720968
warIord
let yor appl. store data into both dbms simultaneously
    #33721765
IgorTaDaDaDa
My application needs data from Universe. I do not need to update data in Universe.
For example, Universe maintains data about a resident. My application on MS SQL needs 'resident' table to function. I want every time a new record added or old record updated in Universe this change triggers INSERT/UPDATE/DELETE in MS SQL.
Igor
