Не могу достучаться до AS400 из MS SQL 2005 используя OLE DB
вот этот Connection работает вне SQL Server [oledb] ; Everything after this line is an OLE DB initstring Provider=IBMDA400.DataSource.1;Password="";Persist Security Info=True;User ID=tomc;Data Source=xxx.xxx.xxx.xxx;Protection Level=None;Initial Catalog="";Transport Product=Client Access;SSL=DEFAULT;Force Translate=65535;Default Collection="";Convert Date Time To Char=TRUE;Catalog Library List=QGPL;Cursor Sensitivity=3 Не могу создать работающий linked server sp_addlinkedserver @server='AS400_OLE', @srvproduct='IBMDASQL.DataSource.1', @provider='IBMDA400', @datasrc='xxx.xxx.xxx.xxx', @provstr='Protection Level=None;Initial Catalog="";Transport Product=Client Access;SSL=DEFAULT;Catalog Library List=QGPL;Cursor Sensitivity=3', @location='QGPL', @catalog='' ; Msg 7399, Level 16, State 1, Line 8 The OLE DB provider "IBMDA400" for linked server "AS400_OLE" reported an error. Access denied. Msg 7350, Level 16, State 2, Line 8 Cannot get the column information from OLE DB provider "IBMDA400" for linked server "AS400_OLE". ... |
| 15.09.2006, 21:59 |
start [/forum/search_topic.php?author=Nikiphoroff&author_mode=last_topics&do_search=1]: |
58ms |
40ms |
| others: | 1253ms |
| total: | 1449ms |
