IBM Workplace 2.5
проблема такая, установил сам Workplace, IBM Directory... далее необходимо активизировать защиту (Enable LDAP security) , читаю доку и делаю все как там написано, но все время возникает одна и таже ошибка: [wsadmin] WASX7246E: Cannot establish "SOAP" connection to host "localhost" because of an authentication failure. Ensure that user and password are correct on the command line or in a properties file. [wsadmin] Exception message (if any): "ADMN0022E: Access denied for the getProcessType operation on Server MBean due to insufficient or empty credentials." [wsadmin] WASX7213I: This scripting client is not connected to a server process; please refer to the log file /opt/IBM/Workplace/AppServer/logs/wsadmin.traceout for additional information. [wsadmin] WASX7017E: Exception received while running file "/opt/IBM/Workplace/PortalServer/config/work/was/SecurityConfigProcs.jacl"; exception information: com.ibm.ws.scripting.ScriptingException: WASX7070E: The configuration service is not available. [wsadmin] ===== in configLTPA [wsadmin] Error: LTPA password needs to be set [exec] Result: 111 [ldapcheck] Checking for 'o=utmn,c=ru' [ldapcheck] Checking for 'cn=wpsadmins,ou=groups,o=utmn,c=ru' BUILD FAILED file:../config/actions/was_cfg.xml:960: Java returned: 1 Total time: 3 minutes 46 seconds кто встречался с такой проблемой или ставил эту систему, подскажите пожалуйста.... а то уже вторые сутки парюсь.... перерыл весь файл "хелпер", но нифига :( ... |
| 25.04.2006, 13:22 |
IBM Workplace 2.5
1. Правим файл (может и не надо???) /opt/IBM/WorkplaceServicesExpress/AppServer/properties/soap.client.props # JMX SOAP connector identity com.ibm.SOAP.loginUserid=wpsadmin com.ibm.SOAP.loginPassword=wpsadmin <-- вписываем наш супер парол 2. отключаем секьюрность =124=0=>/opt/IBM/WorkplaceServicesExpress/AppServer/bin/wsadmin.sh -conntype SOAP WASX7209I: Connected to process "server1" on node novell using SOAP connector; The type of process is: UnManagedProcess WASX7029I: For help, enter: "$Help help" wsadmin>securityoff <- вот это надо ему скормить LOCAL OS security is off now but you need to restart server1 to make it affected. 3. рестарт сервисов #!/bin/sh /opt/IBM/WorkplaceServicesExpress/AppServer/bin/stopServer.sh server1 /opt/IBM/WorkplaceServicesExpress/AppServer/bin/stopServer.sh WebSphere_Portal /opt/IBM/WorkplaceServicesExpress/AppServer/bin/startServer.sh server1 пункт 1 возможно и не нужен, если не выполяеться соединение в пункте 2, убить все жабы, выполнить пунк 3, затем опять 2,3 ... |
| 25.10.2006, 13:25 |
IBM Workplace 2.5
пасиб за ответ, с этой траблой покончено. возникли след проблемы, точнее не проблемы, а не понятки по след вопросам: 1) при регистрации курса (образца) пользователем (отличным от wpsadmin) нет папки для сохранения образца 2) в веб-конференции, при импорте *.ppt и *.doc, теряются картинки (точнее они нулевого размера) 3) Не генерится отчет. Пробовал поставить Xvfb - не получилось (можно ли без него както работать с отчетами?). сама система WCS стоит на Солярке 9. ... |
| 30.10.2006, 06:47 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1605044]: |
34ms |
59ms |
| others: | 255ms |
| total: | 411ms |
