db2diag
Вот db2diag.log : 2007-05-17-17.43.45.524000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 data_protection sqlufrol Probe:100 Database:PFP01_H Rollforward has been initiated 2007-05-17-17.43.45.618000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 recovery_manager sqlpForwardRecovery Probe:20 Database:PFP01_H Invoking database rollforward forward recovery, lowtranlsn 005117690F44 minbufflsn 0051160B4591 2007-05-17-17.43.45.711000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 recovery_manager sqlprecm Probe:125 Database:PFP01_H Using parallel recovery with 3 agents 4 QSets 28 queues and 16 chunks String Title:Redo/undo of nonrecoverable operation. Table object is being marked not available. PID:332489596 Node:000 Table(3:5)=. 2007-05-17-18.14.28.305000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 data_management sqldChangeLifeLSN Probe:739 Database:PFP01_H DIA3806C Unexpected end of file was reached. ZRC=0xFFFFF609 2007-05-17-18.14.28.399000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 data_management sqldChangeLifeLSN Probe:741 Database:PFP01_H New Life should be:0051 29a6 5540 .Q)¦U@ 2007-05-17-18.14.28.477000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 data_management sqldChangeLifeLSN Probe:743 Database:PFP01_H Error changing life of object.0300 0500 0300 0500 0100 0000 0000 0000 ................ 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0000 0000 0101 0000 a700 0000 0000 0000 ........§....... 0010 0000 2000 0000 0100 0000 0300 0501 .... ........... 6801 eb2e 3000 212f h.л.0.!/ 2007-05-17-18.14.28.711000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 database_utilities sqlu_change_obj_values Probe:200 Database:PFP01_H DIA9999E An internal error occurred. Report the following error code : "". ALERT :5 Data Title:Obj Description PID:332489596 TID:9596 Node:000 0300 0500 0300 0500 0100 0000 0000 0000 ................ 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0000 0000 0101 0000 a700 0000 0000 0000 ........§....... 0010 0000 2000 0000 0100 0000 0300 0501 .... ........... 6801 eb2e 3000 212f h.л.0.!/ 2007-05-17-18.14.28.868000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 database_utilities DIAG_ERROR Probe:0 Database:PFP01_H Error!!! -2551, 00000000, Detected in file: d:\db2bld\src\sqluvppo.c, line 1367 Data Title:first object PID:332489596 TID:9596 Node:000 0100 0000 .... Data Title:last object PID:332489596 TID:9596 Node:000 0100 0000 .... Data Title:Obj List PID:332489596 TID:9596 Node:000 0300 0500 0300 0500 0100 0000 0051 29a5 .............Q)Ґ 1b25 0000 0000 0000 0000 0000 0000 0000 .%.............. 0000 0000 0101 0000 2700 0000 0000 0000 ........'....... 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0000 0000 0000 0000 ........ 2007-05-17-18.14.29.196000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 data_management sqldmrdo Probe:701 Database:PFP01_H Tablespace 3 removed from rollforward set due to error xFFFFF609 String Title:Redo/undo of nonrecoverable operation. Table object is being marked not available. PID:332489596 Node:000 Table(4:671)=. 2007-05-17-18.14.35.899000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 data_management sqldChangeLifeLSN Probe:739 Database:PFP01_H DIA3806C Unexpected end of file was reached. ZRC=0xFFFFF609 2007-05-17-18.14.35.946000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 data_management sqldChangeLifeLSN Probe:741 Database:PFP01_H New Life should be:0051 2aae 74d6 .Q*®tЦ 2007-05-17-18.14.36.024000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 data_management sqldChangeLifeLSN Probe:743 Database:PFP01_H Error changing life of object.0400 9f02 0400 9f02 0100 0000 0000 0000 ..џ...џ......... 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0000 0000 0101 0000 a700 0000 0000 0000 ........§....... 0010 0000 2000 0000 0100 0000 0400 9f03 .... .........џ. 6801 eb2e 3000 212f h.л.0.!/ 2007-05-17-18.14.36.149000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 database_utilities sqlu_change_obj_values Probe:200 Database:PFP01_H DIA9999E An internal error occurred. Report the following error code : "". ALERT :5 Data Title:Obj Description PID:332489596 TID:9596 Node:000 0400 9f02 0400 9f02 0100 0000 0000 0000 ..џ...џ......... 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0000 0000 0101 0000 a700 0000 0000 0000 ........§....... 0010 0000 2000 0000 0100 0000 0400 9f03 .... .........џ. 6801 eb2e 3000 212f h.л.0.!/ 2007-05-17-18.14.36.290000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 database_utilities DIAG_ERROR Probe:0 Database:PFP01_H Error!!! -2551, 00000000, Detected in file: d:\db2bld\src\sqluvppo.c, line 1367 Data Title:first object PID:332489596 TID:9596 Node:000 0100 0000 .... Data Title:last object PID:332489596 TID:9596 Node:000 0100 0000 .... Data Title:Obj List PID:332489596 TID:9596 Node:000 0400 9f02 0400 9f02 0100 0000 0051 2aaa ..џ...џ......Q*Є bd59 0000 0000 0000 0000 0000 0000 0000 ЅY.............. 0000 0000 0101 0000 2700 0000 0000 0000 ........'....... 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0000 0000 0000 0000 ........ 2007-05-17-18.14.36.540000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 data_management sqldmrdo Probe:701 Database:PFP01_H Tablespace 4 removed from rollforward set due to error xFFFFF609 2007-05-17-18.36.59.930000 Instance:DB2 Node:000 PID:3324824316(db2syscs.exe) TID:24316 Appid:none data_protection sqlpgart Probe:490 User Exit returned error when retrieving log file S0000617.LOG to F:\DB\ for database PFP01_H, error code 1 2007-05-17-18.37.00.040000 Instance:DB2 Node:000 PID:332489596(db2syscs.exe) TID:9596 Appid:*LOCAL.DB2.070517093518 recovery_manager sqlpPRecReadLog Probe:60 Database:PFP01_H DIA3737C Error occurred while retrieving file during forward recovery. ZRC=0xFFFFE522 2007-05-17-18.37.01.477000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 data_protection sqlufrol Probe:130 Database:PFP01_H Rollforward iteration completed 2007-05-17-18.38.31.071000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 data_protection sqlufrol Probe:100 Database:PFP01_H Rollforward has been initiated 2007-05-17-18.38.31.133000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 recovery_manager sqlpForwardRecovery Probe:20 Database:PFP01_H Invoking database rollforward forward recovery, lowtranlsn 0051BA3E0975 minbufflsn 0051B8DD42AC 2007-05-17-18.38.31.196000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 recovery_manager sqlprecm Probe:125 Database:PFP01_H Using parallel recovery with 3 agents 4 QSets 28 queues and 16 chunks 2007-05-17-18.38.38.915000 Instance:DB2 Node:000 PID:3324824316(db2syscs.exe) TID:24316 Appid:none data_protection sqlpgart Probe:490 User Exit returned error when retrieving log file S0000617.LOG to F:\DB\ for database PFP01_H, error code 1 2007-05-17-18.38.39.008000 Instance:DB2 Node:000 PID:3324820156(db2syscs.exe) TID:20156 Appid:*LOCAL.DB2.070517093518 recovery_manager sqlpPRecReadLog Probe:60 Database:PFP01_H DIA3737C Error occurred while retrieving file during forward recovery. ZRC=0xFFFFE522 2007-05-17-18.38.39.165000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 recovery_manager sqlpForwardRecovery Probe:50 Database:PFP01_H Invoking database rollforward backward recovery, nextlsn: 0051 ba3e 7ff1 .Qє>.с 2007-05-17-18.38.39.305000 Instance:DB2 Node:000 PID:3324819032(db2syscs.exe) TID:19032 Appid:none data_protection sqlpgwlp Probe:910 Ping pong EOL. Dump will follow. Dump File:C:\SQLLIB72\DB2\33248190.000 Data:SQLP_DBCB 2007-05-17-18.38.51.336000 Instance:DB2 Node:000 PID:3324824316(db2syscs.exe) TID:24316 Appid:none data_protection sqlpgart Probe:490 User Exit returned error when archiving log file S0000616.LOG from F:\DB\ for database PFP01_H, error code 1 2007-05-17-18.38.51.461000 Instance:DB2 Node:000 PID:3324824316(db2syscs.exe) TID:24316 Appid:none data_protection sqlpgart Probe:490 Error received from userexit program. DB2 will not call userexit program for this database for 5 minutes. 2007-05-17-18.38.53.258000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 recovery_manager sqlpForwardRecovery Probe:10 Database:PFP01_H Disabled tablespace: 0300 .. 2007-05-17-18.38.53.321000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 recovery_manager sqlpForwardRecovery Probe:10 Database:PFP01_H Disabled tablespace: 0400 .. 2007-05-17-18.38.53.399000 Instance:DB2 Node:000 PID:3324827192(db2syscs.exe) TID:27192 Appid:*LOCAL.DB2.070517093518 data_protection sqlufrol Probe:130 Database:PFP01_H Rollforward iteration completed 2007-05-17-18.38.53.461000 Instance:DB2 Node:000 PID:3324819032(db2syscs.exe) TID:19032 Appid:none data_protection sqlpgspr Probe:2022 Error 1288 when searching message queue for archived logs. Ignore this error. ... |
| 18.05.2007, 09:53 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1604576]: |
48ms |
25ms |
| others: | 227ms |
| total: | 339ms |
