db2advis
Подскажите ,пожалуйста ,что делать У меня DB8 fixpack14 db2advis -d btrhrigl -s "select * from trhtra" выдает ошибку : CALL SYSPROC.GET_DBSIZE_INFO failed (workaround - use -l) SQL0443N Routine "*IZE_INFO" (specific name "") has returned an error SQLSTATE with diagnostic text "SQL1092 Reason code or token: UDB3RHOT ". SQLSTATE=38553 ************************************* * CONTENTS OF SQLCA * ************************************* SQLCABC = 136 SQLCODE = -443 SQLERRMC = *IZE_INFOÿÿSQL1092 Reason code or token: UDB3RHOT SQLERRP = SQLERFRP sqlerrd[0] = 0 sqlerrd[1] = 0 sqlerrd[2] = 0 sqlerrd[3] = 0 sqlerrd[4] = 0 sqlerrd[5] = 0 SQLWARN = SQLSTATE = 38553 Critical SQLCODE. Exiting db2advis ... The insert into the ADVISE_INSTANCE table has failed. 0 solutions were evaluated by the advisor exiting with error code [-443] ... |
| 19.10.2007, 17:25 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1604258]: |
67ms |
| others: | 248ms |
| total: | 371ms |
