IBM's new paradigm for writing Java™ database applications.
See how you can use pureQuery -- IBM's new paradigm for writing Java™ database applications. Three scenarios are described in this demo. The first one is database-driven objectization, or relational table-to-Java transformation. The second is query-driven objectization, or SQL-to-Java transformation. The third is object-relational mapping, or Java-to-SQL transformation. http://www.ibm.com/developerworks/offers/lp/demos/summary/purequery.html?S_TACT=105AGX58&S_CMP=DEMO&ca=dnl-3801demo2 С уважением, Вадим. ... |
| 28.01.2008, 19:17 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1604085]: |
23ms |
53ms |
37ms |
| others: | 265ms |
| total: | 415ms |
