запуск websphere
Websphere 5.3 под AIX 5.3.0.0 при верификации выходит следующая ошибка в чем может быть ошибка? IVTL0095I: defaulting to host server and port 9080 IVTL0010I: Connecting to the WebSphere Application Server server on port: 9080 IVTL0020I: Could not connect to Application Server, waiting for server to start IVTL0025I: Attempting to start the Application Server IVTL0030I: Running /usr/WebSphere/AppServer/bin/startServer.sh server1 >ADMU0116I: Tool information is being logged in file > /usr/WebSphere/AppServer/logs/server1/startServer.log >ADMU3100I: Reading configuration for server: server1 >ADMU3028I: Conflict detected on port 8880. Likely causes: a) An instance of > the server server1 is already running b) some other process is > using port 8880 >ADMU3027E: An instance of the server may already be running: server1 >ADMU0111E: Program exiting with error: > com.ibm.websphere.management.exception.AdminException: ADMU3027E: An > instance of the server may already be running: server1 >ADMU0211I: Error details may be seen in the file: > /usr/WebSphere/AppServer/logs/server1/startServer.log >ADMU1211I: To obtain a full trace of the failure, use the -trace option. IVTL0140E: WebSphere Application Server is not running and could not be started IVTL0035I: Scanning the file /usr/WebSphere/AppServer/logs/server1/SystemOut.log for errors and warnings [07.02.08 12:53:28:009 CST] 4954ee5e WebGroup E SRVE0026E: [Servlet Error]-[COM.ibm.db2.jdbc.DB2Exception: [IBM][CLI Driver] SQL30082N Attempt to establish connection failed with security reason "1" "PASSWORD EXPIRED". SQLSTATE=08001 IVTL0040I: 6 errors/warnings were detected in the file /usr/WebSphere/AppServer/logs/server1/SystemOut.log IVTL0080I: Installation Verification is complete ... |
| 07.02.2008, 14:50 |
запуск websphere
перезапустил сервер AIX ошибка исчезла однако появилась другая: при подключении к Analyzer Error 500: COM.ibm.db2.jdbc.DB2Exception: [IBM][Драйвер JDBC] CLI0616E Ошибка открытия гнезда. SQLSTATE=08S01; nested exception is: org.apache.commons.dbcp.DbcpException: COM.ibm.db2.jdbc.DB2Exception: [IBM][Драйвер JDBC] CLI0616E Ошибка открытия гнезда. SQLSTATE=08S01; nested exception is: com.hyperion.analyzer.utils.exception.repository.b: COM.ibm.db2.jdbc.DB2Exception: [IBM][Драйвер JDBC] CLI0616E Ошибка открытия гнезда. SQLSTATE=08S01; nested exception is: org.apache.commons.dbcp.DbcpException: COM.ibm.db2.jdbc.DB2Exception: [IBM][Драйвер JDBC] CLI0616E Ошибка открытия гнезда. SQLSTATE=08S01 ... |
| 07.02.2008, 15:09 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1604062]: |
53ms |
48ms |
| others: | 219ms |
| total: | 378ms |
