просмотр данных во временной табл
drop procedure res1@ create procedure res1(in prev date, cur date) result set 1 language sql begin declare vr_g33a_4 varchar(4); declare vr_groupkod integer; declare vr_count_countrygroup integer; declare vr_coun_country integer; declare vr_count_4 integer; declare vr_count integer; declare vr_per decimal(15,2); declare cursor_4_cur cursor for select distinct(char(g33a,4)) from session.temp3 order by char(g33a,4); call session.temp3(prev, cur); insert into session.temp2(g33a, s15_17, g41, g31b, g46, g54d)(select g33a, s15_17, g41, g31b, g46, g54d from t_st2005 where char(g33a,4)=any(select distinct(char(g33a,4)) from session.temp3) and s15_17=any(select s15_17 from session.temp3)); insert into res1(name,cost, cost_2)(select 'Всего:', sum(session.temp2.g46), sum(session.temp3.g46) from session.temp2 full join session.temp3 on session.temp2.id=session.temp3.id); open cursor_4_cur; select count(distinct(char(g33a,4))) into vr_count_4 from session.temp3 ; insert into res1 (name) values (null); while vr_count_4<>0 do set vr_count_countrygroup=2; fetch cursor_4_cur into vr_g33a_4; insert into res1 (name) (select char(t.g33a,4) ||' '|| tn.name from tnvedgroup tn, session.temp3 t where char(t.g33a,4)=tn.id || tn.sub_id and char(t.g33a,4)=vr_g33a_4 group by char(t.g33a,4) ||' '||tn.name); insert into res1 (name, count, cost, count_2, cost_2) (select 'Всего:', sum(session.temp2.g31b), sum(session.temp2.g46), sum(session.temp3.g31b), sum(session.temp3.g46) from session.temp3 full join session.temp2 on session.temp2.id=session.temp3.id where (char(session.temp2.g33a,4)=vr_g33a_4 or char(session.temp3.g33a,4)=vr_g33a_4)); select sum(g46)*0.05 into vr_per from session.temp3 where char(g33a,4)=vr_g33a_4; set vr_groupkod=14; while vr_count_countrygroup<>0 do insert into res1 (name, count, cost, count_2, cost_2) (select cg.groupname, sum(session.temp2.g31b), sum(session.temp2.g46), sum(session.temp3.g31b), sum(session.temp3.g46) from countrygroup cg, session.temp2 full join session.temp3 on session.temp2.id=session.temp3.id where cg.groupkod=vr_groupkod and (char(session.temp3.g33a,4)=vr_g33a_4 or char(session.temp2.g33a,4)=vr_g33a_4) and (session.temp3.s15_17=any(select cntkod from countrygroupdef where groupkod=vr_groupkod) or session.temp2.s15_17=any(select cntkod from countrygroupdef where groupkod=vr_groupkod)) group by cg.groupname); insert into dop1(select s15_17, sum(g46), sum(g31b) from session.temp2 where char(g33a,4)=vr_g33a_4 and s15_17=any(select cntkod from countrygroupdef where groupkod=vr_groupkod) group by s15_17); insert into dop2(select s15_17, sum(g46), sum(g31b) from session.temp3 where char(g33a,4)=vr_g33a_4 and s15_17=any(select cntkod from countrygroupdef where groupkod=vr_groupkod) group by s15_17); insert into dop1_2(select dop1.id, dop2.id, dop1.summa, dop2.summa, dop1.count, dop2.count from dop1 full join dop2 on dop1.id=dop2.id); update dop1_2 set s15_17=g15_17 where s15_17 is null; insert into res1 (name, cost, cost_2, count, count_2) (select c.small_name, r.summa1, r.summa2, r.count, r.count2 from country c, dop1_2 r where c.id=r.s15_17 and r.summa2>vr_per and r.s15_17=any(select cntkod from countrygroupdef where groupkod=vr_groupkod)); delete from dop1_2 where summa2>vr_per and s15_17=any(select cntkod from countrygroupdef where groupkod=vr_groupkod); insert into res1 (name, cost, cost_2, count, count_2) (select 'Прочие ' || cg.groupname, sum(r.summa1), sum(r.summa2), sum(r.count), sum(r.count2) from countrygroup cg, dop1_2 r where cg.groupkod=vr_groupkod and s15_17=any(select cntkod from countrygroupdef where groupkod=vr_groupkod) group by 'Прочие ' || cg.groupname ); delete from dop1; delete from dop2; delete from dop1_2; set vr_count_countrygroup=vr_count_countrygroup-1; set vr_groupkod=vr_groupkod-12; end while; set vr_count_4=vr_count_4-1; end while; insert into res1 (name, count, cost) values (null,null,null); insert into res1 (name, count, cost) values (null,null,null); close cursor_4_cur; --delete from session.temp2; --delete from session.temp3; update res1 set prots_k_itogu=(cost_2/cost)*100; end@ ошибка Имя "SESSION.TEMP3" не было определено. LINE NUMBER=15. ... |
| 09.02.2007, 15:24 |
Это вы сильно задвинули: call session .temp3(prev, cur); Ваша процедура temp3 имеет другое имя схемы, она не может иметь имя схемы session . ... |
| 09.02.2007, 15:40 |
Mark BarinsteinЭто вы сильно задвинули: call session .temp3(prev, cur); Ваша процедура temp3 имеет другое имя схемы, она не может иметь имя схемы session . нет это я забыл поправить сори ;) call temp3 ошибка таже SQL0204N Имя "SESSION.TEMP3" не было определено. LINE NUMBER=15. SQLSTATE=42704 ... |
| 09.02.2007, 15:59 |
Ошибка при компиляции или после call res1? Фикспак какой у вас? ... |
| 09.02.2007, 16:10 |
да ошибка при компиляции db2v8.2 фикспак11 кажется ... |
| 09.02.2007, 16:23 |
А в этой же сессии перед компиляцией процедуры вы делаете declare global temporary table session.temp2... declare global temporary table session.temp3... ? ... |
| 09.02.2007, 16:38 |
Mark BarinsteinА в этой же сессии перед компиляцией процедуры вы делаете declare global temporary table session.temp2... declare global temporary table session.temp3... ? в этой же сессии перед drop procedure res1@ ... |
| 10.02.2007, 15:55 |
С ошибкой разобрался но на выходе все еще пусто :( ... |
| 12.02.2007, 07:41 |
Спасибо все отлично получилось .Моя невнимательность была всему виной! ... |
| 12.02.2007, 09:16 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. Кое-как разобрался как тут работать с курсорами и вроде понял как получить и вернуть нужный НД. Процедура компилируется без ошибок, но когда запускаешь выходит ошибка: автор get_accounts_info - Информация запуска была изменена. DB2ADMIN.GET_ACCOUNTS_INFO - Выполнение запущено. Данные, возвращаемые в наборах результатов, ограничиваются первыми 100 строками. Данные, возвращаемые в столбцах наборов результатов, ограничиваются первыми 20 байтами (символами). DB2ADMIN.GET_ACCOUNTS_INFO - Исключительная ситуация при выполнении: Ошибка менеджера баз данных.[IBM][CLI Driver][DB2/NT] SQL0204N Имя "DB2ADMIN" не было определено. SQLSTATE=42704 DB2ADMIN.GET_ACCOUNTS_INFO - Откат успешно выполнен. DB2ADMIN.GET_ACCOUNTS_INFO - Ошибка выполнения. ... |
| 16.02.2008, 13:42 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1604043]: |
199ms |
38ms |
| others: | 229ms |
| total: | 518ms |
