External UDF и *LIBL
Привет. Есть определение внешней функции: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. можно ли както-то вместо узазания конкретной библиотеки специфицировать *LIBL ? При попытке это сделать я получаю ошибку: автор *LIBL contains a character that is not allowed or does not contain any characters. An ordinary identifier must begin with (A-Z, $, #, or @) and be followed by zero or more (A-Z, 0-9, $, #, @, or _). A delimited identifier is a string of characters within SQL escape characters. The characters allowed in delimited names depends on the type of name. -- The characters between the escape characters for system table names, schema names, package names and other system object names can be any characters except Hex 00-3F, Hex 40 (space), Hex 5C (*), Hex 6F (?), Hex 7D ('), Hex 7F ("), and Hex FF. -- The characters between the escape characters for SQL table names, cursor names, statement names, correlation names, column names, procedure names, function names, parameter names, constraint names, user-defined type names, trigger names, or sequence names can be any characters except Hex 00-3F and Hex FF. -- Delimited system column names must begin with (A-Z, $, #, or @) and be followed by zero or more (A-Z, 0-9, $, #, @, or an _). A relational database name must begin with A-Z and be followed by 0 or more letters, numbers 0-9, or an _. Ordinary identifiers that are contained within host variables must not include lowercase letters because they are not converted to uppercase. Recovery . . . : Correct the name. Try the request again. Заранее ... |
| 07.11.2008, 14:50 |
MindWrapper, За С++ ничего не скажу, есть только рабочий пример на C: CREATE PROCEDURE SCHEMA.FUNC_NAME ( INOUT ID INTEGER, IN FNAME CHARACTER(20), OUT ERRORCODE INTEGER ) DYNAMIC RESULT SETS 0 EXTERNAL NAME 'dll_name!funcname' LANGUAGE C PARAMETER STYLE DB2DARI NOT DETERMINISTIC FENCED NOT THREADSAFE MODIFIES SQL DATA NO DBINFO; Предполагаю, что проблема в символе "/". Впрочем утверждать не буду, возможно не совсем правильно понял вопрос. ... |
| 10.11.2008, 09:42 |
Добрый день. MindWrapperЕсть определение внешней функции: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. можно ли както-то вместо узазания конкретной библиотеки специфицировать *LIBL ? http://publib.boulder.ibm.com/infocenter/iseries/v5r3/topic/db2/rbafzmstcfsce.htm Так написано в описании create functoin : EXTERNAL NAME external-program-name Specifies the program, service program, or java class that will be executed when the function is invoked in an SQL statement. The name must identify a program, service program, or java class that exists at the application server at the time the function is invoked. If the naming option is *SYS and the name is not qualified: - The current path will be used to search for the program or service program at the time the function is invoked. - *LIBL will be used to search for the program or service program at the time grants or revokes are performed on the function. Т.е. попробуйте при naming convention *SYS не указывать имя библиотеки - оно должно попытаться найти файл в CURRENT PATH, затем в *LIBL. ... |
| 10.11.2008, 09:55 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1603595]: |
44ms |
35ms |
| others: | 224ms |
| total: | 350ms |
