Download IBM Data Studio Administrator v2.1 ... at no cost
Письмишко сейчас пришло: Prefer reading the Web based version? http://ibm.com/developerworks/ecma/campaign/er.jsp?id=379006&imid=69322828&end Dear developerWorks community member, IBM Data Studio provides an integrated data management environment that offers a comprehensive solution to help you design, develop, deploy, and manage database applications throughout the data lifecycle. Download IBM Data Studio Administrator for DB2 for Linux, UNIX, and Windows V2.1 at no cost. Visit http://ibm.com/developerworks/ecma/campaign/er.jsp?id=379008&imid=69322828&end Improve database administrators (DBAs) productivity and reduce application outages by automating and simplifying complex DB2 structural changes. This helps DBAs easily manage DB2 structural changes, while consistently ensuring data integrity and reducing application downtime. Enhancements for v2.1 include: --New task assistants for common database administration tasks --Faster navigation to the data sources you care about --Initiation of tasks easily and intuitively from the Data Source Explorer Download IBM Data Studio Developer V2.1 at no cost. Visit http://ibm.com/developerworks/ecma/campaign/er.jsp?id=379009&imid=69322828&end Improve development productivity up to 50 percent for developing and testing SQL, XQuery, and Java queries, stored procedures, Web services, and data access layers. IBM Data Studio Developer 2.1 enhancements include: --Reducing or eliminating SQL injection risk for Java database applications --Giving developers more information to focus SQL tuning efforts --Simplifying impact analysis for any databases changes Sincerely, The IBM developerWorks team ***************************** ... |
| 24.12.2008, 07:13 |
Уточнение - я скачал Data Studio Developer, "at no cost" предлагают trial-версию. Тем не менее, с ней идет 2 ключа - бессрочный для основных функций и на 1 мес. - для дополнительных. При установке от дополнительных (они не критичны) можно отказаться, получив бесплатный продукт с постоянным ключом. Единственное "но" - ставил под Windows, под русской локалью у меня установка сдохла. Переключение локали на США и возврат обратно после установки решило проблему. Кстати, Data Studio Administrator пока не качал, но на форуме поддержки утверждают, что в ней тоже есть бесплатная часть. ... |
| 24.12.2008, 17:22 |
Да, извините про триальность. Дело в том, что у меня на работе интернет очень-очень ограничен, почти все сайты закрыты, так письмо получил утром, но по ссылкам сходил только сейчас вот. ... |
| 24.12.2008, 23:27 |
FavnУточнение - я скачал Data Studio Developer, "at no cost" предлагают trial-версию. Тем не менее, с ней идет 2 ключа - бессрочный для основных функций и на 1 мес. - для дополнительных. При установке от дополнительных (они не критичны) можно отказаться, получив бесплатный продукт с постоянным ключом. Единственное "но" - ставил под Windows, под русской локалью у меня установка сдохла. Переключение локали на США и возврат обратно после установки решило проблему. Кстати, Data Studio Administrator пока не качал, но на форуме поддержки утверждают, что в ней тоже есть бесплатная часть.Не понял, а в чем прикол? Скачать можно нахаляву, или пользоваться нахаляву? Ну зашел я по ссылке, перебросило сюда http://www.ibm.com/developerworks/downloads/im/datastudioadmin/learn.html?S_TACT=105AGX63&S_CMP=DLESDca=ddc-, там только Try|Buy|Support. ... |
| 10.01.2009, 18:09 |
db2chaynikНе понял, а в чем прикол? Скачать можно нахаляву, или пользоваться нахаляву?В версии 2.1 нет отдельной бесплатной студии. Вместо этого, в инсталляторе триальной версии отдельно помечены базовые бесплатные функциии, отдельно - триальные платные. Если не ставить триальные, студия будет работать с бесплатной лицензией без ограничений. При этом если в Data Studio Administrator платные фичи действительно вроде полезные, то в Developer - это, как я понял, только расширенный визард для XQuery (XML) и поддержка pureQuery. Последняя имхо вещь сомнительной полезности, к тому же ей нужен весьма платный runtime на сервере. Вот тут совсем недавно соизволили-таки все это подробно объяснить. ... |
| 10.01.2009, 21:59 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1603479]: |
68ms |
50ms |
| others: | 243ms |
| total: | 413ms |
