Что говорит db2diag.log
Подскажите что он говорит по буфер пулу? 2009-06-12-15.27.54.504000+360 I13545H351 LEVEL: Error PID : 2920 TID : 4236 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 FUNCTION: DB2 UDB, buffer pool services, sqlbErrorHandler, probe:0 DATA #1 : String, 75 bytes Obj={pool:47;obj:6;type:0} State=x27 Prefetcher Error, in sqlbProcessRange 2009-06-12-15.27.54.504000+360 I13898H593 LEVEL: Error PID : 2920 TID : 4236 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 MESSAGE : SQLB_OBJECT_DESC DATA #1 : Hexdump, 68 bytes 0x102AB9EC : 2F00 0600 2F00 0600 0000 0000 0238 DDEC /.../........8.. 0x102AB9FC : F449 0000 0000 0000 0000 0000 0000 0000 .I.............. 0x102ABA0C : 0000 0000 0101 0000 2700 0000 0000 0000 ........'....... 0x102ABA1C : 0040 0000 2000 0000 0400 0000 2F00 0600 .@.. ......./... 0x102ABA2C : D0F1 FD01 .... 2009-06-12-15.27.54.504000+360 I14493H364 LEVEL: Error PID : 2920 TID : 4236 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 FUNCTION: DB2 UDB, buffer pool services, sqlbPFPrefetcherEntryPoint, probe:0 DATA #1 : String, 78 bytes Prefetcher Error rc = -2029059854 IGNORED ... err loc 0 . Request follows... 2009-06-12-15.27.54.504000+360 I14859H444 LEVEL: Error PID : 2920 TID : 4236 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 FUNCTION: DB2 UDB, buffer pool services, sqlbPFPrefetcherEntryPoint, probe:0 DATA #1 : String, 159 bytes type = RANGE numranges = 1 SQLB_OBJECT_DESC: objID: 6 PlId: 47 objTyp: 0 Ext Anch: 0 plFlgs: 257 lifeLSN: 0238DDECF449s 6160 n 16 2009-06-12-15.50.30.272000+360 I15305H361 LEVEL: Warning PID : 2920 TID : 4212 PROC : db2syscs.exe INSTANCE: DB2 NODE : 000 DB : MM68 FUNCTION: DB2 UDB, data protection, sqlpghck, probe:1390 MESSAGE : ExtNum 132097, state 401, baselsn 00000348681C2000 nextlsn 00000348682F6273 ... |
| 12.06.2009, 14:42 |
zasik, Что выдаёт команда: LOAD QUERY TABLE tname для tname из: Код: plaintext 1. 2. 3. ... |
| 12.06.2009, 19:38 |
Mark Barinsteinzasik, Что выдаёт команда: LOAD QUERY TABLE tname для tname из: Код: plaintext 1. 2. 3. LOAD QUERY TABLE MM_J.MFILTER; completed successfully. Состояние таблицы: Нормальное состояние ... |
| 12.06.2009, 20:15 |
Похоже, что ОС смогла создать нить, т.к. rc = -2029059854: db2diag -rc -2029059854 ... |
| 12.06.2009, 21:24 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1603210]: |
55ms |
44ms |
| others: | 240ms |
| total: | 390ms |
