SQL0901N The SQL statement failed because of a non-severe system error.
При попытке настроить ODBC коннект через Client Configuration Assistant, при проверке соединения получаю ошибку: [IBM][CLI Driver] SQL0901N The SQL statement failed because of a non-severe system error. Subsequent SQL statements can be processed. (Reason "Invalid Request type for DB2 Admin Server".) ... |
| 07.08.2009, 12:03 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1603144]: |
50ms |
35ms |
| others: | 213ms |
| total: | 334ms |
