Определённый Интеграл
Definite Integral interval [a, b]: Sf(x)dx = G(b) - G(a) where G'(x) = f(x) , or differential of G(x) = f(x). Integrals appear in many practical situations. Consider a swimming pool. If it is rectangular, then from its length, width, and depth we can easily determine the volume of water it can contain (to fill it), the area of its surface (to cover it), and the length of its edge (to rope it). But if it is oval with a rounded bottom, all of these quantities call for integrals. Practical approximations may suffice for such trivial examples, but precision engineering (of any discipline) requires exact and rigorous values for these elements. I create the query which calculate integral of 3 * X^2 - 2 * X in interval [2, 4].... S(3 * X^2 - 2 * X)dx = X^3 - X^2 and exact value of integral will be S = (4^3 - 4^2) - (2^3 - 2^2) = 48 - 4 = 44. We know nothing in our solution about exact value and differential and suppose to calculate approximate value of integral. Process will stop when the absolute difference between current value of integral and previous become less or equal some eps real number . Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. Result of calculation: авторINTEGRAL_VALUE............................ INTEGRAL_IMAGE 4.40005859378289E+001............... interval: [2.0E0, 4.0E0]: S(3 * X^2 - 2 * X)dx = 4.4001E1 Could be very useful for students and engineers. Lenny ... |
| 26.09.2009, 07:23 |
This query is working fast for short intervals. Do not use it for intervals with length > 10.... Also, if you want calculate yours integral, you have to change авторtable (select 3 * power(Xc + step, 2) - 2 * (Xc + step) Fc from sysibm.sysdummy1 ) it and авторSource (Xstart, Xfinish, imgFunc, eps) as (select double(1), double(12), '3 * X^2 - 2 * X', double(1.e-3) from sysibm.sysdummy1 Lenny ... |
| 26.09.2009, 07:26 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1603075]: |
58ms |
42ms |
| others: | 235ms |
| total: | 388ms |
