MESSAGE : Private memory and/or virtual address space exhausted
Система Linux, DB2 v8.1.2.128", "s061108", "MI00176", FixPak "14 В db2diag.log появилась ошибка: 2009-09-28-11.46.47.580736+240 I1G1358 LEVEL: Event PID : 12435 TID : 3086857920 PROC : db2agent (STRAH) 0 INSTANCE: db2inst NODE : 000 DB : STRAH APPHDL : 0-894 APPID: NF000001.C880.090928073550 FUNCTION: DB2 UDB, RAS/PD component, _pdlogInt, probe:120 START : New db2diag.log file DATA #1 : Build Level, 124 bytes Instance "db2inst" uses "32" bits and DB2 code release "SQL08027" with level identifier "03080106". Informational tokens are "DB2 v8.1.2.128", "s061108", "MI00176", FixPak "14". DATA #2 : System Info, 436 bytes System: Linux lin.045.pfr.ru 6 2 i686 CPU: total:2 online:2 Cores per socket:1 Threading degree per core:2 Physical Memory(MB): total:4052 free:110 Virtual Memory(MB): total:8147 free:4205 Swap Memory(MB): total:4095 free:4095 Kernel Params: msgMaxMessageSize:8192 msgMsgMap:16384 msgMaxQueueIDs:1024 msgNumberOfHeaders:16384 msgMaxQueueSize:16384 msgMaxSegmentSize:16 shmMax:268435456 shmMin:1 shmIDs:4096 shmSegments:4096 semMap:32000 semIDs:1024 semNum:32000 semUndo:32000 semNumPerID:250 semOps:32 semUndoSize:20 semMaxVal:32767 semAdjustOnExit:32767 Information in this record is only valid at the time when this file was created (see this record's time stamp) 2009-09-28-11.46.47.580449+240 E1360G553 LEVEL: Severe (OS) PID : 12435 TID : 3086857920 PROC : db2agent (STRAH) 0 INSTANCE: db2inst NODE : 000 DB : STRAH APPHDL : 0-894 APPID: NF000001.C880.090928073550 FUNCTION: DB2 UDB, oper system services, getPrivateChunksFromOs, probe:100 CALLED : OS, -, malloc OSERR: ENOMEM (12) MESSAGE : Private memory and/or virtual address space exhausted DATA #1 : Requested size, PD_TYPE_MEM_REQUESTED_SIZE, 4 bytes 209735680 2009-09-28-11.46.47.605407+240 E1914G553 LEVEL: Severe (OS) PID : 12435 TID : 3086857920 PROC : db2agent (STRAH) 0 INSTANCE: db2inst NODE : 000 DB : STRAH APPHDL : 0-894 APPID: NF000001.C880.090928073550 FUNCTION: DB2 UDB, oper system services, getPrivateChunksFromOs, probe:100 CALLED : OS, -, malloc OSERR: ENOMEM (12) MESSAGE : Private memory and/or virtual address space exhausted DATA #1 : Requested size, PD_TYPE_MEM_REQUESTED_SIZE, 4 bytes 209735680 Появляется после запуска одной операции на клиенте в Вебсфере в логе Вебсферы появляется ошибка: [28.09.09 11:46:47:809 MSD] 0000005d ExceptionUtil E CNTR0020E: EJB threw an unexpected (non-declared) exception during invocation of method "setMessageContent" on bean "BeanId(strah#strahEJB.jar#Scheduler, null)". Exception data: {code=ERR_INTERNAL_ERROR, message=DB2 SQL error: SQLCODE: -930, SQLSTATE: 57011, SQLERRMC: null, comment=null} at com.estylesoft.strah.ejb.scheduler.SchedulerBean.setMessageContent(SchedulerBean.java:46) что можно с этим поделать? ... |
| 28.09.2009, 12:02 |
a_sokol, памяти мало свободной посмотрите в db2mtrk -i -d -v -p сколько отъела база. ... |
| 28.09.2009, 14:51 |
mitek посмотрите в db2mtrk -i -d -v -p сколько отъела база. команда дает такой результат Memory for instance Database Monitor Heap is of size 180224 bytes Other Memory is of size 1261568 bytes Total: 1441792 bytes Memory for database: STRRR Backup/Restore/Util Heap is of size 16384 bytes Package Cache is of size 393216 bytes Catalog Cache Heap is of size 196608 bytes Buffer Pool Heap is of size 211435520 bytes Buffer Pool Heap is of size 1055440896 bytes Buffer Pool Heap is of size 606208 bytes Buffer Pool Heap is of size 344064 bytes Buffer Pool Heap is of size 212992 bytes Buffer Pool Heap is of size 147456 bytes Lock Manager Heap is of size 423624704 bytes Database Heap is of size 10633216 bytes Other Memory is of size 0 bytes Total: 1703051264 bytes Memory for agent 17828 Application Control Heap is of size 16384 bytes Application Heap is of size 212992 bytes Total: 229376 bytes ... |
| 28.09.2009, 15:05 |
a_sokol команда дает такой результат Total: 1703051264 bytes если мне маразм не изменяет, то под Linux32 как раз DB2 может съесть не больше ~1,7Gb. попробуйте уменьшить буферпул(ы) ... |
| 28.09.2009, 15:28 |
mitek если мне маразм не изменяет, то под Linux32 как раз DB2 может съесть не больше ~1,7Gb. попробуйте уменьшить буферпул(ы) к сожалению не силен в этом.. не подскажете как изменить размер этих буферпулов? ... |
| 28.09.2009, 15:37 |
a_sokol к сожалению не силен в этом.. не подскажете как изменить размер этих буферпулов? ALTER BUFFERPOOL Заодно по памяти посмотрите здесь . ... |
| 28.09.2009, 16:08 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1603073]: |
38ms |
46ms |
| others: | 217ms |
| total: | 350ms |
