powered by simpleCommunicator - 2.0.60     © 2026 Programmizd 02
Форумы / IBM DB2, WebSphere, IMS, U2 [игнор отключен] [закрыт для гостей] / DIA8563C An invalid memory size was requested.
4 сообщений из 4, страница 1 из 1
    #36429137
Oleg Kozlovski
может кто-то встречался с подобным?
что тут может быть не так?
db2diag.log
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
2010-01-22-04.16.14.672676+330 I1A1594            LEVEL: Event
PID     : 8728                 TID  : 4398344299056PROC : db2sysc 0
INSTANCE: db2inst1             NODE : 000         DB   : SDB
APPHDL  : 0-38290              APPID: *LOCAL.db2inst1.100121224424
AUTHID  : DB2INST1
EDUID   : 7730                 EDUNAME: db2agent (SDB) 0
FUNCTION: DB2 UDB, RAS/PD component, pdLogInternal, probe:120
START   : New Diagnostic Log file
DATA #1 : Build Level, 152 bytes
Instance "db2inst1" uses "64" bits and DB2 code release "SQL09054"
with level identifier "06050107".
Informational tokens are "DB2 v9.5.0.4", "s090429", "MI00304", Fix Pack "4".
DATA #2 : System Info, 440 bytes
System: Linux g28lcihttp01 6 2 ppc64
CPU: total:2 online:2 Cores per socket:1 Threading degree per core:2
Physical Memory(MB): total:8048 free:1405
Virtual  Memory(MB): total:16240 free:9597
Swap     Memory(MB): total:8192 free:8192
Kernel   Params: msgMaxMessageSize:65536 msgMsgMap:65536 msgMaxQueueIDs:1024
                 msgNumberOfHeaders:65536 msgMaxQueueSize:65536
                 msgMaxSegmentSize:16 shmMax:9223372036854775807 shmMin:1
                 shmIDs:4096 shmSegments:4096 semMap:256000 semIDs:1024
                 semNum:256000 semUndo:256000 semNumPerID:250 semOps:32
                 semUndoSize:20 semMaxVal:32767 semAdjustOnExit:32767
Cur data size (bytes)  = 0xFFFFFFFF
Cur stack size (bytes)  = 0x00800000
Cur core size (bytes)  = 0x00000000
nofiles (descriptors)  = 0x0000FFFE
Information in this record is only valid at the time when this file was
created (see this record's time stamp)
2010-01-22-04.16.14.672594+330 I1596A2166         LEVEL: Warning
AUTHID  : DB2INST1
FUNCTION: DB2 UDB, SQO Memory Management, sqlogmblkEx, probe:1000
MESSAGE : ZRC=0x820F0004=-2112946172=SQLO_MEM_SIZE "Mem Mgt invalid size"
DATA #1 : String, 43 bytes
Memory management block allocation failure.
DATA #2 : Codepath, 8 bytes
2
DATA #3 : Memory pool handle pointer, PD_TYPE_MEM_POOL_HANDLE_PTR, 8 bytes
0x000004001bfa0ce8
DATA #4 : Requested size, PD_TYPE_MEM_REQUESTED_SIZE, 8 bytes
0
DATA #5 : Adjusted block size, PD_TYPE_MEM_ADJUSTED_SIZE, 8 bytes
0
DATA #6 : Options for requested block, PD_TYPE_GET_MEM_OPTIONS, 4 bytes
0x00000000
DATA #7 : Pointer to address that will be set by new allocation, PD_TYPE_PTR_TO_ADDRESS_OUT, 8 bytes
0x0000040011bf07b0
DATA #8 : File name, PD_TYPE_OSS_MEM_FILE_NAME, 13 bytes
sqlnr_rule5.C
DATA #9 : Line of code, PD_TYPE_OSS_MEM_LINE_NUM, 8 bytes
3857
DATA #10: Resource binding pointer, PD_TYPE_RESOURCE_BINDING_PTR, 8 bytes
0x0000000000000000
CALLSTCK:
  [0] 0x0000040000F11A70 /home/db2inst1/sqllib/lib64/libdb2e.so.1 + 0xEA8A70
  [1] 0x0000040000F0FBC8 pdLog + 0xFFFFFFFFFBF00608
  [2] 0x0000040002874FCC sqlogmblkEx + 0xFFFFFFFFFD7E33EC
  [3] 0x000004000255B308 _Z16sqlnr_count_qncsP9sqlnq_qunPPiS1_ + 0xFFFFFFFFFD4D8D10
  [4] 0x0000040002482F40 /home/db2inst1/sqllib/lib64/libdb2e.so.1 + 0x2419F40
  [5] 0x0000040002484210 _Z20sqlnr_reorder_IJ_qgmP9sqlnq_qunP9sqlnq_oprPP13sqlnq_deplistPiP3loc + 0xFFFFFFFFFD404648
  [6] 0x00000400025F506C _Z20sqlnr_qrwprep_phase2P3locPi + 0xFFFFFFFFFD570C2C
  [7] 0x0000040002410BD4 _Z18sqlnr_prep2_actionP10sqlnr_qrwaPiP14sqlnr_progress + 0xFFFFFFFFFD39265C
  [8] 0x00000400025A4B4C _Z10sqlnr_compPiiP16sqlnr_rule_stateP10sqlnr_qrwaP14sqlnr_progress + 0xFFFFFFFFFD52157C
  [9] 0x00000400025A5054 _Z9sqlnr_seqPiP10sqlnr_qrwaP14sqlnr_progressP12sqlnr_rclass + 0xFFFFFFFFFD521A6C
db2mtrk -i -d -v
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
Memory for instance
   Other Memory is of size 14548992 bytes
   FCMBP Heap is of size 851968 bytes
   Database Monitor Heap is of size 327680 bytes
   Total: 15728640 bytes
Memory for database: SDB
   Backup/Restore/Util Heap is of size 65536 bytes
   Package Cache is of size 33816576 bytes
   Other Memory is of size 196608 bytes
   Catalog Cache Heap is of size 917504 bytes
   Buffer Pool Heap (3) is of size 70451200 bytes
   Buffer Pool Heap (2) is of size 8781824 bytes
   Buffer Pool Heap (1) is of size 16056320 bytes
   Buffer Pool Heap (System 32k buffer pool) is of size 851968 bytes
   Buffer Pool Heap (System 16k buffer pool) is of size 589824 bytes
   Buffer Pool Heap (System 8k buffer pool) is of size 458752 bytes
   Buffer Pool Heap (System 4k buffer pool) is of size 393216 bytes
   Shared Sort Heap is of size 1179648 bytes
   Lock Manager Heap is of size 655360 bytes
   Database Heap is of size 40566784 bytes
   Application Heap (456) is of size 65536 bytes
   Application Heap (455) is of size 65536 bytes
   Application Heap (454) is of size 65536 bytes
   Application Heap (453) is of size 65536 bytes
   Application Heap (400) is of size 65536 bytes
   Application Heap (317) is of size 65536 bytes
   Application Heap (251) is of size 65536 bytes
   Application Heap (113) is of size 65536 bytes
   Application Heap (112) is of size 65536 bytes
   Application Heap (111) is of size 65536 bytes
   Application Heap (110) is of size 65536 bytes
   Applications Shared Heap is of size 2162688 bytes
   Total: 177864704 bytes
    #36429473
Mark Barinstein
Oleg Kozlovskiможет кто-то встречался с подобным?
db2diag.log
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
AUTHID  : DB2INST1
Дюже много цифр...
Поставьте в /etc/sysctl.conf
kernel.shmmax=1073741824
как указано в Modifying kernel parameters (Linux) .
    #36456201
Oleg Kozlovski
Mark BarinsteinДюже много цифр...
попробовали - не помогает.
уж очень текст ошибки наводит на баг в самой DB2...
    #36460439
Mark Barinstein
Oleg Kozlovski,
покажите опять тот же кусок из db2diag.log после исправлений и, если есть, последующие ошибки после DIA8563C.
