Можно ли из функции запустить хранимую процедуру?
пытаюсь сделать вот так: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. Функция создалась, но при выполнении получаю ошибку: SQL0751N Routine "TEMP.MOVE_MONEY" (specific name "MOVE_MONEY") attempted to execute a statement that is not allowed. Я понимаю, что сделал функцию как-то "с извращениями" :о), подскажите пжлст, как сделать правильно? ... |
| 11.03.2010, 11:18 |
db2 "? SQL0751N" SQL0751N Routine "<routine-name>" (specific name "<specific-name>") attempted to execute a statement that is not allowed. Explanation: The program used to implement the body of a routine is not allowed to issue any connection statements. If the routine is a function or method, COMMIT and ROLLBACK (without the SAVEPOINT option) are also not allowed. If the routine is a procedure and is called within a trigger, function, method, or dynamic compound statement, a COMMIT or ROLLBACK statement is not allowed in the procedure. ... |
| 11.03.2010, 12:05 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1602855]: |
44ms |
38ms |
| others: | 201ms |
| total: | 329ms |
