Параметры при создании таблиц
Привет Подскажите пожалуйста начинающему. Что значат следующие параметры при создании таблицы. Код: plaintext 1. 2. 3. 4. 5. и Код: plaintext 1. 2. 3. ... |
| 30.09.2010, 15:56 |
IN TSIOMMM1 - в каком tablespace создавать. NOT LOGGED INITIALLY - изменения будут без логирования: Any changes made to the table by an Insert, Delete, Update, Create Index, Drop Index, or Alter Table operation in the same unit of work in which the table is created are not logged. For other considerations when using this option, see the "Notes" section of this statement. All catalog changes and storage related information are logged, as are all operations that are done on the table in subsequent units of work. Note: If non-logged activity occurs against a table that has the NOT LOGGED INITIALLY attribute activated, and if a statement fails (causing a rollback), or a ROLLBACK TO SAVEPOINT is executed, the entire unit of work is rolled back (SQL1476N). Furthermore, the table for which the NOT LOGGED INITIALLY attribute was activated is marked inaccessible after the rollback has occurred, and can only be dropped. Therefore, the opportunity for errors within the unit of work in which the NOT LOGGED INITIALLY attribute is activated should be minimized. NOT VOLATILE - Specifies that the cardinality of table-name is not volatile. Access plans to this table will continue to be based on existing statistics and on the current optimization level. Все тут: InfoCenter ... |
| 30.09.2010, 16:25 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1602560]: |
56ms |
30ms |
| others: | 252ms |
| total: | 387ms |
